I just installed the Diablo sport 60 hp setting, onto my f350 7.3L... When I reach 5th gear I beleive, the transmission seems to stick in nuetral for a few seconds reving the engine, then switches to 5th gear... Is this the transmission slipping? It never did this before! Maybe I have to get used to the new tune?
im assuming its a manual transmission, and i bet its something with the clutches. im new to modding the engines, and totally naive to manual transmissions, so i cant recommend the sonnax valve.
getting the sonax in your tranny and putting an addition cooler on it is the best money you can spend on your tranny... it will shift the way it is supposed to and will last longer... one tip... don't run the firm or hard shift settings on your predator after you get the sonnax installed...
since the automatic transmissions back then were only 4 speed, it led me to believe that you had a manual. and i was wondering if you were keeping some secret about another hidden gear inside the transmission...
The torque converter makes the 4 speed auto seem like it has 5 gears.
