Pulls to right in breaking
Old Jul 20, 2005 | 02:06 AM
oricle's Avatar
oricle
At higher speeds(around 55), if I ever have to push the break down my truck pulls hard to the right. Does this sound like a bad left caliper?
Old Jul 20, 2005 | 07:55 AM
mrsuperman15's Avatar
mrsuperman15
do you have oversize tires on your truck?
Old Jul 20, 2005 | 11:51 AM
AseTim's Avatar
AseTim
You either have a left caliper that doesn't work or a right one that is seizing/sticking. First thing you should do is make sure your caliper sliding/mounting surfaces are cleaned and lubed.
Old Jul 20, 2005 | 12:21 PM
oricle's Avatar
oricle
ya, would that cause it to go one way more than the other though?
Old Jul 20, 2005 | 12:45 PM
quicklook2's Avatar
quicklook2
what if rotors, both calipers and pads are all new? same size tires and air pressure the same.
Old Jul 20, 2005 | 12:50 PM
AseTim's Avatar
AseTim
Are you experiencing the same problem? If all compnenets are new It still could be a caliper mounting problem or even a master cylinder problem. another thing I forgot to mention to the original post is a line that is restricted.
Old Jul 20, 2005 | 01:13 PM
oricle's Avatar
oricle
In this I want to replace bolth capilers right? Should I replace the break pads while I'm at it?
Old Jul 20, 2005 | 01:57 PM
andym's Avatar
andym
Didn't you post this in the brakes forum as well?
Multiple postings are a bit of a no-no here. Your question will get answered no matter where you post it. Many people read more than one forum.
Like I said, replace the calipers (BOTH), and the hoses as well. Make sure the slides are in good shape and lubed properly, and see if it pulls. If it does, it's probably the tires or alignment.
Old Jul 20, 2005 | 01:58 PM
AseTim's Avatar
AseTim
Don't replace anything until you pinpoint the problem, otherwise you could nickel and dime yourself to death. first get those front wheels off and check your
caliper mounting surfaces also check condition of brake pads. If surfaces are dirty(mounting surfaces not friction) clean with wire brush and blow off, lube with light grease (synthetic). if this doesn't solve it raise the front of the vehicle and spin the tires by hand and see if one side has more drag than the other, if nothing is detected after doing this aplly the brakes and relaes and recheck wheel rotating drag (by hand) if one wheel is now notciably tighter than the other you have either a sticking caliper piston or a brake line that in't allowing
pressure to release and to determine which one is at fault loosen bleeder screw on side that is tight (careful not to break it) now if the wheel spins freely it is a line problem if it does not it is a caliper problem. If it passes that test you probably have a master cylinder or brake pad problem.
Old Jul 20, 2005 | 02:14 PM
oricle's Avatar
oricle
Thanks. I'll get started on that tomorrow.
Old Jul 20, 2005 | 09:04 PM
Popa Tim's Avatar
Popa Tim
Check the e-brake cable at the juntion under the drivers side bed just rear of the cab. its where one cable goes into a bracket and two come out and head to the rear. If one rear brake is stuck on that bracket will not be straight up and down and one rear brake will work a whole lot better than the other causing a pull.
Hope you find it,
Popa Tim
Old Jul 21, 2005 | 02:19 PM
alz's Avatar
alz
Don't forget to check your radius arm bushings. I had one go bad and when I would brake the truck would pull to that side. Doesn't cost anything to check.
Old Jul 21, 2005 | 05:06 PM
Popa Tim's Avatar
Popa Tim
Amen to that!
Popa Tim
Umaxman
All Things Towing
May 30, 2008 10:09 AM
BSEXTON
Feb 19, 2008 09:56 PM
oricle
Jul 21, 2005 04:45 PM
springer9861
Mar 23, 2004 07:15 PM
NChevyRehab
Oct 24, 2001 09:44 AM
