460 valley pan
Old Jul 19, 2005 | 11:30 AM
dedne's Avatar
dedne
460 valley pan
I am starting to put together a 460 for my 77 f250 4x4. My question is: Is a valley pan needed on a 77 460? If one is not needed is it worth it to add one? Please let me know the facts and your opinions. Thanks.
Dave
Old Jul 19, 2005 | 08:19 PM
Bear 45/70's Avatar
Bear 45/70
If you are using the heat riser cross over in the intake manifold, then yes you need too. If your manifold has no crossover or you use a blockoff kit, then no. The valley pan keeps oil off the hot exhaust cross over passage under the carb which burns the oil and causes nasty build up.
Old Jul 20, 2005 | 12:32 PM
dedne's Avatar
dedne
Thank you for the responce. Since this is pretty much a stock build I will use the valley pan. Thanks again.
Old Jul 21, 2005 | 12:14 PM
fasthauler's Avatar
fasthauler
Definitely use the pan, you should see the cruddy oil that comes out of an engine that they have been left off of.
Old Jul 21, 2005 | 02:42 PM
460me's Avatar
460me
Doesn't the pan help keep the manifold cooler? Helps keeps the hot oil off of it?
Old Jul 21, 2005 | 02:48 PM
Bear 45/70's Avatar
Bear 45/70
The oil is not nearly as hot as the exhaust cross over passage. I alway ran a valley pan, even when I blocked the cross over for racing. In that case it does help keep the manifold cooler.
77truck460
Jun 18, 2016 08:24 PM
redneck_davis
Apr 20, 2015 04:27 PM
77_F150_4x4
Jan 8, 2008 12:04 AM
Jeff Fisher
29
Apr 28, 2006 04:54 PM
airharley
Dec 14, 2002 10:01 AM
