baking soda in gas tank please respond asap
what ever happened to the good old snickers bar?
While working at a gas station I had this girl come in and get gas. I wasn't paying too much attention. After a while I got to thinking she has been out there a while pumping real slow. I called out on the intercom and asked if everything was all right. she said yes and would explain when she came in to pay. She was driving a 92 chevy cavalier holds what 10-11 gallons. She finished up at about 6.5 gallons. It took her over 30 minutes to pump. someone she knew decided to play a prank on her. THEY FILLED HER TANK WITH PEA GRAVEL!!!!!!!!! I about peed myself I was laughing so hard. She lived with it until she could raise the money for a new tank.
And yes she was Blond. I didn't have the heart to tell her to just have the tank drained.
Seems to me that if you drained the tank, dropped it, flushed it out with clean gas, and replaced the filter on the pick up tube, that would take care of the tank. What ever small amount of baking soda that got into the fuel lines (and if the truck was not started there should not be any) the fuel filter will remove. I'd be more worried about the in-tank fuel pump being damaged than the truck's motor if the truck was started. Then, after say 100 or so miles, change the fuel filer, and I think you'll be good to go.
Try putting baking soda in a glass of gas to see if it is soluble. Baking soda (NaHCO3) melts at 518 F, so it should disassociate in the combustion chamber into CO2 gas, leaving behind NaOH (sodium hydroxide). That should leave the exhaust with the water generated during combustion, leaving a basic residue that is slightly corrosive in the exhaust. It's slightly soluble in alcohol, so you could add some isopropyl alcohol to the gas tank to speed up the process.
Other than the abrasive problem previously mentioned, it doesn't sound as bad as sugar or sand. Baking soda is pretty finely ground, so how bad can that be. Still, somebody needs a whupping.
