Aerostar Ford Aerostar
Stalling at startup
Old Jul 17, 2005 | 05:42 AM
razor_jim's Avatar
razor_jim
Stalling at startup
Okay guys, really need your help here. My '89 3.0L has been getting this problem over the last few days. When I start the engine, it idles low and seems to rise up and down, like it's struggling to idle, and the engine shakes, and it actually stalled when I revved the engine the other day to see if it would cure the problem. It's also starting to do this act when I'm sitting at a red light. The battery indicator bounces up and down with this rough idle.
I had a similar problem a couple of years ago, don't remember how it got fixed though...
What could the problem be? Time's of the essence, I have a big trip coming up this Thursday and I gotta figure out if it's a problem I can live with for a week or if I have to race my Aero over to a mechanic's shop right away.
Thanks!
Old Jul 17, 2005 | 07:15 AM
MarlboroKlingon's Avatar
MarlboroKlingon
I had the same problem with my '87 Mustang 2.3L.
As far as I could tell, it was my TPS. (Throttle Position Sensor).
Do you have a 'Check Engine' light lit, after the self test finishes?
I was never able to prove it was that sensor that was bad, but all signs pointed to it. Since I was broke and couldn't afford to replace it right away, I opted for the real cheap fix - I simply unplugged it and manually set the idle so as to be just high enough to not stall with the car in drive and the A/C on.
I sold the 'Stang shortly thereafter, as it was too much of a money pit.
Good luck.
Old Jul 17, 2005 | 09:13 AM
copper_90680's Avatar
copper_90680
Vacuum leak or Idle Air Controller. Lots of people here have reported that the IAC can be cleaned. I'll try that first to see if that's the problem.
Old Jul 17, 2005 | 10:22 AM
Bear River's Avatar
Bear River
Former ******
Yes, the controller can be cleaned, but it is more often than not, beyond cleaning, in which case replacement is the only option. TPS would ncause idle problems, but it woud definately cause problems if you tried to apply throttle. In fact, the above post must be referring to the Idle bypass, because if you unplugged the TPS the engine would either not run at all, or throttle responce would be very sluggish. (and I mean very sluggish).
Old Jul 17, 2005 | 01:44 PM
krankshaft's Avatar
krankshaft
To test if its your IAC what I do is disconnect the 2 wire connector from it.
Make sure the van is in park hold the gas pedal down a little to maintain idle and start it up while holding the pedal if the engine doesn't shudder or shake replace your IAC.
If it still shakes look into your TPS or O2 sensor.
Your TPS is to the left on the other side of the throttle plate where the linkage connects to it. It is secured by two screws.
Your O2 sensor is the little gold can screwed into the exhaust before the cat.
Old Jul 17, 2005 | 01:47 PM
razor_jim's Avatar
razor_jim
Well I don't have problems getting the van to move, it drives like it usually would, just as soon as I stop, it'll get into this rumbling engine sort of thing after a few seconds.
Old Jul 17, 2005 | 01:50 PM
krankshaft's Avatar
krankshaft
Its probably your IAC then because when you release the gas pedal and the throttle plate closes the engine would be starved for air and stall.
If your IAC is clogged it might be letting enough air to idle but not idle smoothly.
Old Jul 17, 2005 | 02:23 PM
JTHill24's Avatar
JTHill24
Or check the Vacuum tee and see if one of the Vacuum lines popped loose.
Old Jul 17, 2005 | 02:34 PM
razor_jim's Avatar
razor_jim
Just did that. At first, the Aero didn't want to start, I turned the key and just got a big CLICK. Messed with the battery wire, did what you told me with the gas pedal...
Engine sat at a steady idle with my foot on the pedal, died when I took my foot off, and was still doing the bouncy deal when I plugged the IAC back in.
So is IAC indeed the problem? Where's the best place I can find a replacement part in a hurry if it is?
Old Jul 17, 2005 | 02:44 PM
93nighthawk's Avatar
93nighthawk
Yep, your IAC is th e issue.
I would try cleaning it with some Carb cleaner, or seafoam/berrymans. If that does not work, any auto parts store will carry it.
Old Jul 17, 2005 | 02:48 PM
razor_jim's Avatar
razor_jim
Awesome. I'll let you all know later tonight how everything went, I'm gonna zip on over to Autozone and get the part, I'm not risking anything.
If it works, you guys have once again saved a fellow Aerostar owner's life.
Old Jul 17, 2005 | 03:26 PM
razor_jim's Avatar
razor_jim
They shoot, they score!
Problem solved, no more jumping. You guys should have capes or something, freakin' super hero stuff. I'm saved again by the crew here on this board.
Old Jul 17, 2005 | 03:34 PM
93nighthawk
Being a little melodramatic aren't you Jim?
Glad we could be a service to you.
Old Jul 17, 2005 | 07:51 PM
MarlboroKlingon
Correction
I'm not sure what I was thinking when I posted my reply, but I meant to say IAC instead of TPS.
Sorry, lol
Quite correct that a disconnected TPS would result in severe problems - Though a disconnected IAC wouldn't change too much, and might smooth out things in some cases. (Though it'd probably play hell with emissions control..)
Old Jul 18, 2005 | 10:38 AM
krankshaft's Avatar
krankshaft
I wanted to make sure I knew where the IAC was one day when I was under the hood checking the fluids so I pulled the wire and checked if the engine would start . Then to make sure I got the right one when it wouldn't start I held the pedal to make it idle and when I released it and it died I knew I found the IAC.
I'm sure there are other methods of troubleshooting like just slightly pressing the gas and seeing if the engine holds steady it but I'm a simple person and like to disconnect any parts I can during troubleshooting .
I wasn't sure why the TPS would come into play with a rough idle either M but I just posted where it was anyways .
Glad we could be of assistance .
