Rear Differential Leaking
Old Jul 16, 2005 | 08:12 PM
edub32's Avatar
edub32
Hey guys...my rear differential has been leaking for quite some time but only a little bit so I didn't think much of it at the time. It now looks like it is leaking quite a bit and has been a cause for concern. It is leaking right by the cover. Hopefully it is just the gasket and nothing serious. Do you guys have any good websites or anything about changing out the gasket and where to get one??
Thanks again
Old Jul 16, 2005 | 08:24 PM
touchofgrey's Avatar
touchofgrey
Thanks again
I hope it's the cover. But you need to crawl under there and see if there is a trail leading from the companion flange where the pinion seal is. It will run all the way back to the cover seam....then drip. Just a thought.
Old Jul 16, 2005 | 08:39 PM
edub32's Avatar
edub32
I'll check that out Touchofgrey, I'm pretty sure it's just the gasket..it looks like a pressure leak. I'll get a pic up in a little bit
Old Jul 16, 2005 | 08:48 PM
touchofgrey
If it looks like a pressure leak.....better yank that vent hose off and make sure it isn't plugged up. Also take out the steel fitting that it hooks to in the axle tube. My hose was fine, but the fitting was plugged with rust.
Old Jul 17, 2005 | 12:35 AM
rusty350250's Avatar
rusty350250
in responce to the gasket question, there is no gasket per sey, it is just silicone you can buy at any auto parts store for 4$ a tube i have used hi temp and normal and never had a problem. hope it is just the cover seal.
Old Jul 17, 2005 | 12:50 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That's correct. There is no gasket, just sealant.
I agree with touchofgrey. If you've got a pressure leak, you've got a plugged vent.
Old Jul 17, 2005 | 01:46 PM
edub32's Avatar
edub32
Here's a pic of my problem...does it look like I just need sealant? It's leaking on to my driveway so that's not a pressure leak right?
Old Jul 17, 2005 | 01:55 PM
edub32's Avatar
edub32
btw, I tried tightening all the bolts and they won't budge...
Old Jul 17, 2005 | 02:01 PM
ford390gashog's Avatar
ford390gashog
just pull it off and re seal it. you are probably low on fluid too.
Old Jul 17, 2005 | 02:04 PM
edub32's Avatar
edub32
My rear cover is really bad too. It's pretty rusty and is just falling apart. Do you guys know any place with good prices for a new differential cover?
Old Jul 17, 2005 | 02:08 PM
ford390gashog
just don't buy those crappy chinese ones off ebay. you can try ford or a offraod supply.
Old Jul 17, 2005 | 02:13 PM
SpringerPop's Avatar
SpringerPop
His pinion seal could also be the cause. A leak will be blown back to the rear, and the dirt will carry the stain up through it by capillary action.
So don't rule out a seal yet. Let's have a picture taken from the front.
Pop
Old Jul 17, 2005 | 02:31 PM
edub32's Avatar
edub32
Left side:
Right Side:
Old Jul 17, 2005 | 02:37 PM
edub32's Avatar
edub32
I don't see any fluid in the front whatsoever. I will try to get a front bottom pic in a little bit.
touchofgrey
You took pics of everything except where you need to be looking. The area we're interested in is where the u-joint attaches to the differential. The bottom side of the differential in that area running to the back is how to tell if the Pinion seal is leaking.
In any case....from what little I can see from the pics it looks like it's dry, so your probably right in the cover leaking.
One other thing....I see that your differential vent hose is just laying across there. It needs to be attached up in the right frame rail with that plastic part pointing towards the back of the truck. That way you don't get water in you differential.
