Manual Transmission 2004-2005 F350 6.0PSD
I have a 2005 F350 PSD and my brother in law had a 2004 F350 PSD, both have 6 speed manuals and 410 rear ends. We tow 32 ft livestock trailers, that loaded weigh between 20k and 28k. The problem is we have to ride the clutch at times to start off. Had an 01 F350 7.3L PSD 6 speed manual with 410 rear end and it pulled with no problem. The 05 Dodges with Cummins and 6 speed manual and 373 rear end pull a lot better. I don't think the problem is in the motor or the rear end gear, since most I have talked to like their automatic transmission in the 2005 F350, I think Ford must have changed the transmission when they went from a 7.3 to a 6.0. Was wanting to know if anyone knew of anything that could be done to the gearing in the 6 speed manual transmission of a 2005 F350 PSD, because I like the rest of the truck a lot better than the Dodge, just want it to pull better, espeacially in the lower gears.
Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Must read if you own a 6.0
https://www.ford-trucks.com/forums/s...d.php?t=325000
See you on the boards.
Enjoy FTE …..
Enjoy FTE …..
I've never towed that much weight, but I would think that in low, you should be able to start out just fine without slipping the clutch. The shift from low to 1 takes a bit to get used to, but is managable. I know what you mean about the Cummins with a bit more low end, but that's the nature of the beast.. -An Inline 6. As you've mentoined, yes, all around the Ford is a much better truck interior wise than the Dodge. Overall, it's just a better truck. You ask if there's a difference with the 6spd from the 7.3 or the later 6.0's. Not that I'm aware of. I did a small amount of research when I was looking for a new truck. I settled on the 6.0 and ZF. And in my inquiries never found anything different with the ZF's except clutch, input, and output bearings. I was never told about any gear ratio differences.
-Steve
-Steve
BigDaddy6969
Ford vs The Competition
42
07-30-2010 12:15 PM
66 BADBOY
1999 to 2016 Super Duty
67
08-13-2009 05:36 PM
bayernrudi
22
01-06-2005 10:54 AM
