f250 2000 7.3
f250 2000 7.3
tried to start truck key on, no dash lights, no radio, starts buzzing under dash will not stop buzzing unless you turn lights on, or disconnect battery. batteries are fully charge when you try to turn key abs light and air bag light blink. lights will not turn on either "happy diesel owner"
checked batteries 12.2- 12.4 volts each one (interstate batteries) cables clean. when key turned on no dash lights at all, no lights on radio. headlights will not come on or interior lights have been having to lift gearshift to make sure in park to crank over.
Biloxi dude, give me a PM with contact info and I can maybe come over and add my .02 cents.
given your latest clue leads me to believe you have a bad switch indicating truck is in park. you need this for starting consent. any truck / car will do exactly your symptom if you try to start it in drive.
Plus we could swap in my red tops which are known good batteries.
on
Agreed with the comment about load testing. I had same problem on 2-year old batteries (as in 23 months old). Lots of disco lights, buzzing, all sorts of problems, and no start. Yet, they would ohm out at 12.4 - 12.8. When I went to get them load tested (charged them up overnight, and was lucky enough for the truck to start)...turned out one was BAD and other was getting there soon.
richardjd
1999 to 2016 Super Duty
10-26-2020 06:41 AM
nicksorenson
07-18-2017 07:07 PM
Fordenthusiasts
04-23-2011 10:19 AM
