propane or turbo ?
Old 07-09-2005, 04:52 PM
crazy_driver's Avatar
crazy_driver
crazy_driver is offline
propane or turbo ?
Im looking at ither putting a turbo on my 7.3 but i hear the propane is just as good what would be the better choice and the cheapest.
i do a lil bit of towing but mostley empty
1990 F250 7.3L diesel 4x4
Old 07-09-2005, 07:12 PM
shorthair's Avatar
shorthair
shorthair is offline
cost wise propane i think but ease of use turbo though i have neither on mine yet.
Old 07-09-2005, 10:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
ATS turbo is the ticket www.atsturbo.com
Old 07-11-2005, 01:34 PM
RawPower's Avatar
RawPower
RawPower is offline
Turbo is way better. nothing beats more air and fuel. ATS, hypermax, CTS, Banks...all hte same thing. ATS is the best quality though.
Old 07-11-2005, 02:23 PM
IABill's Avatar
IABill
IABill is offline
Another vote for turbo-charging I have never use propane but I think for low maint a T-charger is the way to go. I have the Hypermax kit on my M/H the only change I plan to make is getting some ducting to the airfilter for cooler air I am not impressed with the placement of the filter sitting right about center of the motor EGT's get a littel hot but nothing that backing out of the throttel won't correct. But let me tell ya the T-charger flattened out the hills its pretty fun to hang at 70 to 75 up-hill down-hill everywhere.....Bill
Old 07-11-2005, 06:05 PM
deanj's Avatar
deanj
deanj is offline
Turbo is the way to go, I vote for ATS. Will give you better performance. Do not forget to modify your intake More Air In - More Exhaust Out. Put in a decent set of guages PYRO first before you turn up the pump.
Old 07-11-2005, 06:08 PM
theshyguy's Avatar
theshyguy
theshyguy is offline
turbo whine. Need I say more?
Old 07-11-2005, 06:59 PM
Dave Sponaugle
That is the sweetest whine you will ever hear.
And the three inch downpipe and exhaust is also a must.
After you run that for a while, when you want more power, then you can add the propane and get a real kick.
The NA motor just can not get enough air to really turn the fuel up and run propane to get a good kick.
Old 07-12-2005, 01:22 AM
crazy_driver
thanks everone
Old 07-14-2005, 03:20 AM
Grok's Avatar
Grok
Grok is offline
If you have a turbo put it make sure the shop knows how to mod your IP and try to take it to a turbo/turbine nerd. They do the best work and can usualy be found running a small shop in an industrial area near an airport. It will be more than a regular turbo but it will kick harder.
If you do propane the upfront cost will be much less like $300-800 even less if you get used parts (used tanks and regulators are easy to come by). Compaired to turbo which start at $1000. However, you will have to build on a liquid propane tank and buy propane which is $1.80-2.50 around here. So, over the long hall (years/thousands of miles) propane will outprice a turbo unless you abuse the turbo.
My personal conclusion; if you got the $ get a turbo... i'll be running propane.
Dylan
Old 07-18-2005, 03:15 PM
85IDIDiesel's Avatar
85IDIDiesel
85IDIDiesel is offline
I am going to go against what everyone else is saying.
how much do you want to spend. I built a propane kit for less than $200. It added so much fuel mileage that it doesn't cost anymore to run than running straight diesel. Also it adds more power than the turbo. I have had turboed trucks and non turboed trucks with propane. Propane adds more power. Now I have a truck with propane and a turbo. Real sweet.
Old 07-18-2005, 04:49 PM
bilder12's Avatar
bilder12
bilder12 is offline
I like the turbo idea. You dont have to keep refilling the tankwith propane and it will last a long time. Go thru different altitudes with propane and adjusting is necessary, the turbo doesnt need constant attention. ATS is the system that Ford used on their factory system in 93-94. Its your scooter and your wallet. Enjoy the ride either way.
Harleyboy61
46
08-04-2016 10:03 AM
evan.kelly978
06-12-2012 10:18 AM
89ford73
Bio-diesel, Propane & Alternative Diesel Engine Fuels
22
12-12-2011 02:31 PM
rootbeerford
05-12-2007 01:40 AM
f350custom
64
01-26-2007 01:50 PM
Quick Reply: propane or turbo ?
