Sponsored by: Real Truck
ABS codes?
Old Jul 8, 2005 | 11:50 PM
habsfn's Avatar
habsfn
ABS codes?
Does anybody know how to get the ABS codes out of a 2000 f-350 the ABS light stays on all the time it only flashes once at start up. Any help would be great.
Old Jul 9, 2005 | 05:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and member notified
Old Jul 9, 2005 | 06:44 AM
high ho silver's Avatar
high ho silver
The ABS system is very sensitive. Unless you can spot an obvious defect with the wires or other parts of the system, you probably need to change the switch/sensor located in the rear axle "pumpkin". They have a magnet on them and will pick up small shards of metal from the axle internal cause a bad reading back to the ABS system. Also if you have 4WABS you could go as far as to check for mud, rust, crud on the front sensors. Look for the extra wires going down by the fron brake hoses into the back of the hubs.
wolfmanagh
Apr 29, 2011 06:56 AM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
haroutd
Jan 2, 2003 08:19 PM
petuniapus
1978 - 1996 Big Bronco
Apr 23, 2001 09:03 PM
