need diesel c6 info
need diesel c6 info
I pulled my tranny today to rebuild over the weekend. Is it true that the torque conv. on the diesel c6 does'nt have to be replaced during a rebuild? I've been told that you just flush'em out. If someone could enlighten me on this before I do something stupid, I would greatly appreciate it
scott
scott
the trans was rebuilt about a year ago so it only has about eight to ten thousand on it. I got the truck for $500 from my cousin because it was slipping in second gear. When I checked it out I found that the firewall insulation had come loose and was pushing down on the kickdown rod all the time. So I'm assuming that had something to do with it slipping. I decided to go ahead and replace the clutches and put in a shift kit while I'm there.
If it was slipping in second gear, it could be as simple as just a second gear band adjustment. The adjustment can be done with the tranny still in the truck and is quick and easy. I would adjust that first and then see if that works before pulling the trans.
Hmm, reread your first post, I guess the trans is already pulled. Oh well.
scottie2hottie
18
09-02-2019 09:52 AM
