Are Hydrogen Powered cars the future?
#32
Originally Posted by Flash635
In ideal conditions - water.
Under Ideal conditions, the only byproduct of burning gasoline would be CO2 and H20. So, what about in the real world where we would be using H2 in an internal combustion engine. What would the byproducts be?
#33
#34
Originally Posted by 76supercab2
Cool a greenhouse gas!!!
But there is one possible nasty byproduct, NOx (mostly NO2) if the temperature in the combustion chamber is high enough. NO2 can cause smog and ozone depletion when the humidity is low (i.e. Los Angeles); with water it will make nitric acid which can lead to acid rain.
There are several ways to combat NOx, and rest assured, if a hydrogen powered engine ever goes into production, NOx will be taken care of one way or another.
#35
Originally Posted by aurgathor
http://en.wikipedia.org/wiki/Greenhouse_gas
http://www.eia.doe.gov/oiaf/1605/ggccebro/chapter1.html
http://yosemite.epa.gov/oar/globalwa...Emissions.html
Now, since the current, best way to obtain hydrogen is by steam reformation of natural gas (AAAAAAAAAHHHHHHh and EVIL!!!! Hydrocarobon!!!!!), the hydrogen produced is not from water. Meaning that if it is burned in an oxygen atmosphere, you will be adding water to the environment. AND, now that I think of it, you'll also be depletingt the atmosphere of Oxygen. And producing a green house gas (water vapor).
But the fun doesn't end there. The byproduct of steam reformation (besides H2) is ..................... (wait for it ) .....................
Ding ding ding!!!!! CARBON DIOXIDE!!!!! MORE green house gas!!!! Yea!!!!!!
Obviously, if there are some burnable particles (i.e. pollen) or some gas (i.e. methane or H2S) they'll get burned, too, but for all practical purposes they can be ignored because the concentration of them should be small enough. Some lubricants can also burn off, but that should also be negligible, as well as wear metals that exit via the exhaust.
My point is not to discount H2 as an energy carrier (ie battery, it is not an energy source because you have to put too much energy into it's production to use it). It may very well come into common use. But, no matter what the actions of man are, there will ALWAYS be consequences. Best to look at the whole picture so as not to be surprised further down the road.
#36
That was a good post, 76supercab2.
It just goes to show that The Powers That Be don't want to fix the problem, just to be seen to be doing something.
I don't know what emmissions burning H2 in real world conditions would be and I don't know how to find out.
White Coats only ever do things in controlled lab conditions.
It seems to me that LPG, or propane as you call it, is still a pretty good option.
#37
h
Now THERE, is a complete explanation.
#38
Also, modern wind generators have radar which can detect flocks of migratory birds, and the generators stop when birds are in the way
If you want to get political think of it this way. It's not the value of fuel that's gone up. A gallon of fuel will only do the same work it did last year. Your money just isn't worth as much as it used to be.
#39
#40
Rest assured aurgathor, my chemistry studying days are well and truly over.
I still don't know where I could find independant results for emissions testing of a hydrogen burning, road going vehicle.
I know where I can get laboratory produced results in sterile conditions, hell, I could work it out myself.
I won't be fitting a hydrogen cell to my 1996 Explorer.
I will be fitting a computer controlled, sequential, vapour injected LPG system though.
#41
Originally Posted by tdford
I'd just set up a "chicken" processing plant at the base of the towers and let the mills keep turning. Better yet, just set out a spread of decoys and some hunter dummys. That will keep the birds flyin' high.
The Japs will pay top dollar for food from the endagered and close to extinction list.
That's a good point about the dollar value of the fuel.
Worldwide oil prices is one of the biggest hoodwink jobs ever.
#42
#44
#45
Liquified Petroleum Gas does not come from petroleum? Propane (C3H8) and Butane (C4H10) cannot be refined directly from methane (CH4). Gas-To-Liquids technology to get heavier hydrocarbons from natural gas has not yet been put in large scale production.
Such hydrocarbons may be a by-product of hydrogen production at refineries if natural gas (and a lot of energy) is the feedstock. LPG has always been part of the output stream of crude distillation.
Jim
Jim
