Start up rattle
Old Jan 7, 2006 | 12:05 PM
mikemic's Avatar
mikemic
I don't believe that 5w20 has ever been recommended for the 4.0 SOHC, so 5w30 is the oil to use. Are you still under warranty? If so, I'd have it checked for the timing chain problem before the warranty expires.
Old Jan 7, 2006 | 04:29 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by pvwollan
My 2004 Explorer does the same thing at start up after it's been sitting overnight. It's been like that since just after the warranty ran out. I've tried different oil filters(Fram, Motorcraft, SuperTech, Purolator) all do the same thing. It's definitely lubrication related. If I remove the starter relay, crank the engine by jumping the contacts without having the ignition on for a few seconds, letting oil press. build up, and then reinstall the relay and start the engine normally. There is no noise. I think the oil is draining back out of the heads after the engine has been shut down over a certain period of time. The only fix I can think of is to install a preoiler to build oil pressure before the engine is cranked.
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 7, 2006 | 06:01 PM
Ken00's Avatar
Ken00
You may want to also check with the guys in our Eplorer forum.
