Water spray on IC?
Yes and yes. Most people build there own setups using a windshield washer reservoir, washer pump, and in ground garden sprayer parts form Home Depot or Lowes. I have even seen pulling trucks wet down the IC before a pull with one of those hand pump pressurized sprayers. I was going to build one for my 99 for use on the dyno, but didn't because it would have bumped me up a class in the dyno competition. The club I belong to that runs the dyno comp, and makes the class rules said this was because they had seen previous trucks make significant gains with sprayer systems. Even if it had worked really well, it would have put me in the class with twin turbo Dodges and I would not have been competitive. Another thing to look into is Nitrous sprayer kits. These are starting to gain popularity with the import crowd. They work on the same principle except they spray nitrous on the IC instead of water. It would be a good bit more expensive both in initial cost and long term use, but dyno tests have shown a good increase in power, at least on gas powered cars. Think about it this way: going down the road at about 60 mph, roll down the window and stick your hand out, feels about the same as the ambient air temp, now stick your hand in a bucket of water, water temp isn't really important, and stick it back out the window, feels much cooler then ambient.
Use a WOT switch available from most nitrous suppliers and wire it to what ever you have set up to spray water. One thing to remember about water sprayers is mount the reservoir and pump low, if the nozzles are lower then the top of the reservoir the the nozzles will leak. You could wire in a 3 position momentary switch ( on-off-on as long as you hold the switch ) that way flip the switch to the left it is on until you turn it off or it runs dry, or flip it to the right for short bursts, it automaticly turns off when you let off the switch.
I'm one of these guys that thinks alot. Got to thinking when i read this. Wouldn't it be cool (no pun intended) if you could run your intake air through an A/C unit like the one in your dash. Its not that big and would provide all the cold air you want! I know they suck power so it would be no good for dyno pulls were you want every little bit of horsepower but on a daily driver i notice no real differance with my A/C on or off. Hmmmm? Now i have myself thinking agian!
A guy on TDS dreamed up the AC cooled IC, some engineer guy. it was pretty much a break even, or lose HP thing, no gain.
I think we might be getting water INJECTION confued for water spray here. I don't see water on the IC giving much cooling, or enough to notice an EGT difference. NOs, maybe. I think CO2 would give some cooling to, but if it got into your intake, bye bye fun. CO2 would snuff it out.
Now if you really wanna lower your EGT's, do water injection.
'pane will mostly likely keep your EGT's the same, but boost will come up, so you might see a lower EGT.
Diesel Rod
Diesel Rod
444Dieselrod is correct water/meth injection will lower egts, as will nitrous injection to a point. What I was talking about was external water and/or nitrous sprayers which also will lower egts to a point. Water sprayers come from WRC. Rally cars use water sprayers to combat heatsoak, a condition where the IC gets hotter then the air passing through it there by rendering it useless. I have seen guys spray everything, IC, IC tubes, the turbo itself. Does it make power, well not directly, but by cooling egts, there by allowing you to cram more air and fuel in, then yes it could make some power. Is it worth it for a mild daily driver, probably not, it is more for the all out puller or racer, trying to get that last little bit of power.
Originally Posted by edub32
Does propane increase egts?
Max
