Remove the (2) 7mm screws above the instruments.
Set park brake and shift vehicle to 1st gear.
Pull dash bezel towards you, you will need to disconnect the light switch, message center switch, and 4WD switch.
Once bezel is removed, the radio can be removed by removing the 7mm screws on either side of it.
