gluing molding/trim back on...?
Old 06-28-2005, 11:09 AM
RICE H8R's Avatar
RICE H8R
RICE H8R is offline
RICE H8R is starting off with a positive reputation.
Red face gluing molding/trim back on...?
On the drivers door of my pickup the rubber molding/trim (about 2" tall, black with chrome stripe in the middle)...whatever you want to call it...is peeling off. What could I use to attach it to the door again?? Some sort of glue perhaps and put pressure on the trim until the glue dries? Where the trim is peeling off the door is right at the front of the door, so it's peeled up a good 3-4 inches from hitting the fender.
I hope that makes sense. I'm trying to get it fixed before the end of July, since I will be taking my senior pictures, and will be taking some with my pickup.
Thanks!
L8R from Rice H8R
Old 06-28-2005, 11:51 AM
kingfish51
kingfish51 is offline
kingfish51 is starting off with a positive reputation.
You can purchase double sided foam tape for auto trim. As the foam can deteriorate, using some kind of glue may not work. Best probably to remove the trim totally, remove the old tape on whichever part it is stuck to, clean the 2 surfaces thoroughly and put on new two sided tape.
A lot of work, but probably the only way to ensure it stays on.
Old 07-04-2005, 05:05 AM
ryaneverk2's Avatar
ryaneverk2
ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
There's a glue called "Trim and badge adhesive" or something like that, made by 3M. I think I got it at Wally World. It seems to work pretty well. I think it was a couple bucks for a small tube of it. Good luck.
PS - I think it's a black tube, with yellow lettering on it. Can't remember for sure.
Old 07-04-2005, 10:35 AM
getnbz
getnbz is offline
getnbz is starting off with a positive reputation.
i use that stuff that Ryan mentioned it works great. they also make a weatherstriping in a tube used that on my ventshades good stuff
Old 07-06-2005, 01:04 AM
fomoco_1's Avatar
fomoco_1
fomoco_1 is offline
fomoco_1 is starting off with a positive reputation.
Whichever method you use be sure to prep the area well. A good and thorough wipe down with alcohol will help adhesion. I prefer using the 2 sided tape.
blwn88cpe
2009 - 2014 F150
02-06-2017 01:41 PM
CountryBumkin
04-12-2015 07:33 AM
RICE H8R
Appearance & Dress-Up
11-04-2005 06:51 PM
RICE H8R
08-12-2004 10:02 PM
RICE H8R
Exhaust Systems
18
01-02-2004 05:51 PM
Quick Reply: gluing molding/trim back on...?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
