1978 - 1996 Big Bronco
Trans Temp Sender-AOD.
Old Jun 27, 2005 | 11:26 AM
CaseyJones's Avatar
CaseyJones
I got an Autometer Pro Comp Ultralite Trans Temp guage. I do remember reading that the sender is probably to long to go into the side of the trans and that it might sheer off.
1. What Trans temp sender part #do I need from Autometer (the Autometer tech I spoke with contradicted himslef to many times in a 5 minute call to have earned any credability)
2. Which port on the side of the AOD trans do I need to use for best results? (physical location relative to TV test port?)
3. Should I just put this sender in a T fitting inline to sample the hot oil on its way to the cooler, will this still be accurate if T is located closer to the cooler and further from the trans?
Thanks for any whisdom or experience.
Tony
86 Bronco 5.0 AOD
SoCalAngler
28
Jan 11, 2024 10:44 AM
jarrodh
Mar 16, 2013 10:21 PM
larspetter123
23
Aug 19, 2011 04:54 PM
Welk49
Jun 27, 2008 04:50 PM
jnye6625
Mar 22, 2007 11:25 AM
