o2 sensor problem
Old Jun 24, 2005 | 08:43 PM
wipper's Avatar
wipper
o2 sensor problem
so i'm writing this here to see if anyone in this area can help.
i have a 2001 excursion with a 5.4 . i live in NY so to get an inspecton they connect to the computer. well the computer says
oxygen sensor not ready
oxygen sensor heater not ready
i have gone to a dealer and they said it should set but simply driving it
well 5 days later 50 miles a day no change
HELP!!!!!
Old Jun 24, 2005 | 08:51 PM
Franklin2's Avatar
Franklin2
Check all your fuses, especially the big ones under the hood. I think there may be a fuse for the oxygen sensor heater.
Old Jun 25, 2005 | 12:36 AM
wipper's Avatar
wipper
i'll check the fuses in day light tommrow
Old Jun 25, 2005 | 12:28 PM
Franklin2's Avatar
Franklin2
I looked at the diagram, and there is a fuse #19, 20 amp in the fuse box under the hood. I don't know if this is the problem though, since it also feeds something on the tranny and the EGR on the engine. So if it was blown, you should have some other errors too. If you can't find a fuse blown, I would follow the exhaust pipes down from the engine, till you see a sensor screwed into the pipe. Check the wiring to make sure it's in good shape. You should have a sensor for each side of the engine. The red/yellow and red/white wires feed the heater on one side, and a red/yellow and yellow/lightblue wires feed the other side. The other wires in the sensor send the air to fuel info to the computer. But the sensor has to be hot enough, or it won't work.
Has anybody also suggested changing the sensors?
Old Jun 25, 2005 | 09:32 PM
wipper's Avatar
wipper
i had a problem with my o2 sensors earlyer this year the ford dealer found broken wires in the wiring harness and "repaired it".
i think they sodered the wires backwards.
well talking to a different dealer i have to go back to the first dealer for any type of warrantee......... so i'll let you know how this ends
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Oct 13, 2016 04:48 PM
Easytime
Jun 23, 2013 09:37 PM
Travistjm1
Jun 23, 2013 06:35 PM
mjstef
Feb 8, 2007 08:29 AM
