inigtion switch removal
Picture 1: Put your key in the ignition switch and turn it to the "RUN" position. (Right before the START postion.) There is an access hole (red arrow) on the bottom cover that allows you to insert a screwdriver or a hole-punch to release the lock cylinder.
https://www.ford-trucks.com/user_gal...=80454&width=0
Picture 2:
Look in that hole with a flashlight and you'll see a ball-bearing looking item. This picture has the switch out so you can see the ball-bearing retaining mechanism better. (Red arrow)
https://www.ford-trucks.com/user_gal...=80455&width=0
Picture 3: With the key on "RUN", insert the screwdriver and push the ball-bearing inward and then grasp the lock cylinder and pull it out like you would pull out a key. It just snaps back into place when you want to put it back.
https://www.ford-trucks.com/user_gal...=80453&width=0
