Hissing sound when brake pedal depressed
i am pretty new to explorers so i can take a stab at this....
i had a 83 marquis before i got my truck and there was a very common problem that sounded like this. If you can hear the hissing and it sounds like its inside the cabin check under the dash at the base of the steering column. Check for any vacuum lines right there and see if you can see where any leaks might be coming from.
In the marquis specifically there was a vacuum valve there to pop the e-brake when you put the car in gear if it was left on...this valve always broke and would cause the same thing. Check for something similar.
yeah thats a lot of work to do before he even knows the booster is bad.
to check for a vacuum leak do the following...
start the truck and pop the hood (in any order you see fit)
take a can of WD40 and spray around the vacuum lines and fittings on the brake booster...if the idle surges then you have a leak there...if not it oculd still be a leak...only inside the drum....This WD40 trick works for most vacuum lines...
whiskeyrichard
10-03-2012 01:38 PM
datchew
22
04-19-2005 09:14 AM
