Vin # research
Old Aug 10, 2005 | 07:58 AM
77300i6's Avatar
77300i6
My truck came with a vin# plate on the passenger side firewall right above the heater hoses. I think someone called it a buck tag
Old Aug 10, 2005 | 10:47 AM
quehele's Avatar
quehele
Here's what I found.
Originally Posted by darnash
Wondering if you could help me decode a vin# for a 1978 Ford Pickup? The VIN is F14BLCD9824. The reason is everything says F150 on the truck but the title is listed as a 3/4 ton. Any idea? Any help would be appreciated. Thank you.
Results for VIN#: F14BLCD9824
Model Year: 78
Series: F150 - 4x4 Pickup
Engine: 6 Cyl, 300ci (4.9L) 1bbl
Assembly Plant: Michigan Truck
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
Hope this helps.
Old Aug 10, 2005 | 11:06 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thanks. Actually the title is listed as .75 in that section.
Not to be dumb as a rock, but what section? I'm in NY, they don't list the "tonnage" of pickups as 1/2 or 3/4 on the title.
They DO list the GVWR for commercial or curb weight for passenger cars.
Old Aug 10, 2005 | 11:23 AM
Mil1ion's Avatar
Mil1ion
For people needing to decode their truck info,I don't know why people just don't send others to my web site where one can decode the rating plate themselves
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Aug 10, 2005 | 11:26 AM
Mil1ion's Avatar
Mil1ion
RE : Quote Post #2
and
Quote Post #13:
I actually have no clue, but the 3/4 ton doesn't match with the "F14" part of your VIN.
I've never seen a title list "3/4 ton" but I've spent all my life in NY, what do I know
My Reply to the original post in Post #8
F14SLBJ5405
F14= F150 4x4
S = 400
L= Michigan Truck plant
BJ5405 = Truck number 5405 built in March 1978
Old Aug 10, 2005 | 12:56 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Well I know in california that you can put heavy duty springs, brakes and things to beef up a vehicle and get the gvwr reclassified.
I know a few people to do that around here where I live... I have a friend with a 1960 F-500 that is now close to being a F-900.
Another possibility, it could also be the GVWR is right where the cut off is. Your F-150 might be able to haul close to 3/4 ton, but has the brakes wheels and axles of a typical F-150. The F-250 has better brakes and heavier axles etc...
Just my two cents.
Old Aug 10, 2005 | 02:38 PM
1975Ford's Avatar
1975Ford
I've seen the tag on the truck box.
Old Aug 10, 2005 | 03:41 PM
Mil1ion's Avatar
Mil1ion
The GVWR for an F14 coded truck is 6050lbs
Old Aug 10, 2005 | 06:41 PM
darnash's Avatar
darnash
Thank you for all the help. I really appreciate all of the replies and they were all very helpful. The GVW is listed at about 6000 lbs so it all fits for a 1/2 ton. Thanks again.
Old Sep 17, 2005 | 10:48 AM
princepack's Avatar
princepack
Got all that decoding for 1994 and newer vehicles? I'd love to have it.
cndfarm99
21
Oct 11, 2014 04:34 PM
jmm
Jan 11, 2008 07:31 PM
bruce fraser
Oct 11, 2004 02:15 PM
kuttawa
Mar 12, 2004 07:55 AM
tojaho
Oct 19, 2003 02:03 PM
