Momentary Purge Valve Squeal on Start Up
Old 02-03-2015, 07:12 PM
F150Dad's Avatar
F150Dad
F150Dad is offline
Hey guys, my son brought this to my attention the other day. On first start up, or after sitting for a couple of hours, there is a noticeable squeal when he starts his truck. The truck runs fine, idles fine, no misfiring or any noticeable engine issues that would point towards a vacuum leak.
I changed the hose that runs from the Purge Valve to the manifold almost a year ago. Expensive little sucker, about $68.00 bucks.
Any idea on why it has started squealing? I can't tell if it is a sucking squeal or a discharge squeal. It is momentary only. Any ideas?
Old 02-04-2015, 11:21 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
If the temperatures are quite low, the squeal is possibly the drive belt slipping a small amount.
My truck does this when the temps are around 10 degrees or lower on first start, then goes away right after cranking.
If this is what happenes on your truck I would not worry about it.
Good luck.
Old 02-04-2015, 11:29 AM
F150Dad's Avatar
F150Dad
F150Dad is offline
I guess that could be what we are hearing. I'm in coastal Texas, so below 40 is considered freezing to us .
I will keep a closer watch on it, we are suppose to get into the mid 30's this weekend. Thanks BG7
FarmingF250
2009 - 2014 F150
11-17-2017 03:27 PM
tolliewolly
09-29-2010 08:08 PM
kawa
15
04-06-2009 10:34 PM
adipose
06-25-2008 05:56 PM
jakes29
Bronco II
01-17-2005 08:47 PM
Quick Reply: Momentary Purge Valve Squeal on Start Up
