gear whine?
Old 06-21-2005, 09:23 AM
osbornk's Avatar
osbornk
osbornk is offline
I took mine in this morning to get the gears replaced. It took a couple of months to get my parts. They kept getting backordered because they had a supplier problem (replacing bad parts with bad parts was no help). I know the parts manager personoally and he was getting terribly frustrated trying to get the parts and being unable to do it. At least it gave the dealership time to send their mechanic to a Ford school for training on how to install the parts (the mechanic who installed the first one got into an argument with the female service manager and found out it's not a good idea to make a woman mad and is now looking for a job).
Old 06-22-2005, 08:52 PM
micabeau1's Avatar
micabeau1
micabeau1 is offline
Took my truck in for service today...
Rear window leak was fixed. Now I have to schedule a date for the rear end whine. But my biggest fear was overcome when the dealer told me they could hear it. I was worried they would deny their was a problem.
The dealer says this is probably a two day fix, one to crack it open and fix, but a second day in case they need to get parts from another dealer. Does this sound right to you guys?
Mike
Old 06-22-2005, 09:16 PM
kfx400_1124's Avatar
kfx400_1124
kfx400_1124 is offline
The dealers are having problems with vendors to get parts in. It took four weeks to get a new ring and pinon, and only a half a day to install.
Originally Posted by rcknrbn
Garman - what was the turn-around time for the rear end fix? I put mine in the shop 12 days ago and it still isn't repaired yet. They called me after 5 days to tell me the ring and pinion gear set was on order. Last week, they called to tell me parts should be in by Thursday, 6/16. As of today, I still haven't heard back from the dealer.
The dealer is providing a rental (an '05 F150 Screw) so I'm being patient. I'm just curious how long this repair should take once they have parts in hand.
Old 06-23-2005, 06:12 AM
micabeau1's Avatar
micabeau1
That worries me. The service guy talked like they would crack it open and figure out which parts they needed, then go get them.....
We'll see
Mike
Old 06-24-2005, 09:20 PM
osbornk's Avatar
osbornk
osbornk is offline
Originally Posted by micabeau1
That worries me. The service guy talked like they would crack it open and figure out which parts they needed, then go get them. Mike
They have a complete service kit that includes everything they need for the repair. It took a couple of months to get mine and they told me flat rate is 6 hours to install. I took mine on Tuesday at noon and got it back Wednesday afternoon. The delay was caused bu them having to find a couple of tools to complete the repair. The first mechanic (since fired) apparently guessed when the proper tools weren't handy. The fix worked and it is very quiet now.
Old 06-24-2005, 10:28 PM
micabeau1's Avatar
micabeau1
do you have an invoice with some kind of part # for the kit???
Thanks
Old 06-25-2005, 01:45 PM
osbornk's Avatar
osbornk
osbornk is offline
Thanks
No but there is a TSB out on it (you may need to do a search) so they are well aware of it. The backorder was for the 3.73 LS rear and I even called Ford and they confirmed that the information from the parts department was accurate.
