code reader for OBD I
Old Jun 10, 2005 | 12:43 PM
BergerFromage's Avatar
BergerFromage
i'm about to buy a 91 F150 with a 300, i think it might be useful to get a code reader. were can i buy a code reader for the old OBD I? i can only find them for the OBD II.
Old Jun 10, 2005 | 02:05 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
I'm not sure where to get the machine. I'd invest in a 6 foot wire, but that's me... it's simple to pull the codes by counting the blinks on the check engine light.
Ryan
Old Jun 10, 2005 | 02:06 PM
88F-150pimp's Avatar
88F-150pimp
The have them in the JC whitney catalog for about 25 bucks. However, you can get a piece of wire, ground out the self test imput (the one little indepentent connecter at the ECU test harness), turn the ignition to run, and the codes will flash on the check engine light. It's cheap, but in my opinion, hard to interpret, so i would just buy a code reader.
Old Jun 10, 2005 | 02:12 PM
BergerFromage
i was reading how to do to the self test with the wire, and that sounds real complicated.
i'm new to the fuel injection world i'm used to working on my 66 mustang
it's wierd how i can completely rebuild an engine, transmission, rear end, and pretty much anything else in a car, but then when it comes to wires and computers i'm completely stumped
Old Jun 10, 2005 | 02:23 PM
FghtinIrshNvrDie
I'm swearing by the wire trick. What you're doing is grouding the test program, and you count the blinks... it really is quite simple if you try it 2-3 times.
Ryan
Old Jun 10, 2005 | 02:31 PM
BergerFromage
i'll try it
do you have a website that describes it better than this one or do you have any suggestions?
http://fordfuelinjection.com/
Old Jun 10, 2005 | 02:32 PM
FghtinIrshNvrDie
hmm, stick with that website. it may talk technical, but the process itself is simple. All you're doing is grounding that wire, and counting blinks and pauses.
Ryan
Old Jun 10, 2005 | 02:37 PM
quicklook2's Avatar
quicklook2
the haynes manual describes this well if i remember. it is not complicated.
Old Jun 10, 2005 | 05:17 PM
andym's Avatar
andym
Then you're in trouble, because it's about as complicated as changing your oil.
Old Jun 10, 2005 | 07:08 PM
quicklook2's Avatar
quicklook2
your post made me laugh out load. you are sooooo funny!
Old Aug 28, 2007 | 12:27 AM
Navy Jet Mech's Avatar
Navy Jet Mech
I'd say it's easier, once you've figured out how to interpret the blinks...no getting under the truck!
Old Aug 28, 2007 | 05:15 AM
StealthWyvern's Avatar
StealthWyvern
and not to mention no messy oil and filters!
Old Aug 28, 2007 | 06:20 AM
92F150Flare's Avatar
92F150Flare
I bought mine at Advance Auto.....$30.......I tried counting the blinks twice.....kept looking down at the paper instead of the light and spent way too much time trying to figure out how long 2 and 4 seconds was....
Advance had them in the store but when I got ready to buy it I went on their website and saw they offered 2-3 different ones. Mine is the INNOVA 3145 model. I'd bet any auto parts store has them but I didn't check any others.
Good Luck
Bob
Old Aug 28, 2007 | 07:43 AM
Scndsin's Avatar
Scndsin
I just make "tally" marks: llll, slash. I don't have to take my eyes off the light.
I also use an Actron device, about 25$, their cheapest one. It beeps (helps) as well as flashes the light. NO DISPLAY! Just keeps me from having to go around the door, or hang over the window sill.
Still nothing that can't be accomplished with a paper clip.
Old Aug 28, 2007 | 08:12 AM
quicklook2's Avatar
quicklook2
innova 3145 electronic, shows numbers, has memory, does koeo and koer and checks for dead cylinders.
do an ebay search.
