BAJA_SD Service Record for 2005 PSD
I had the “brilliant idea” to record all my trucks service history in this thread and add to it as things occur. Maybe if enough of us do this a dedicated forum for service records could emerge.
My truck is a White 2005 F250 PSD CrewCab FX4 Lariat with all options except Moon Roof, Electronic Shift-on-the-Fly, PTO and Snow Plow Package. Specifically ordered the 17 inch wheels because of availability of tires. I ordered it in January 2005 from Kearny Mesa Ford in San Diego and took delivery February 15, 2005 with 18 miles on the odometer.
04/01/05 5,038 Miles
5,000 mile service at Kearny Mesa Ford. Coupon for free service used. Asked them to check serpentine belt and pulleys for wear and residue because I often smell burnt rubber from the belt area. They reported everything was fine.
04/02/05 5,054 Miles
Replaced my stock 17 wheels and BFG tires with "take off" factory 18 inch wheels and Continental tires with 200 miles on them that I got for $400.00.
05/07/05 8,009 Miles
Dropped truck off at Kearny Mesa Ford to have the Service Engine Soon light evaluated. Told them that if they re-flashed it not to change the tire size. Also asked them to check out the front end for steering wheel shake over small bumps and told them about the related TSB. Asked them to check the air conditioning as I don't think it is blowing cold as it should. Again, asked them to check the serpentine belt for wear as I am still smelling burnt rubber and see residue around the pulleys.
050905 8025 Miles
Picked up the truck. Service Engine Soon light is due to a bad Fuel Sender in the tank - part on order. I'm going to have the connection checked because it may have come loose after the Transfer Flow tank install. Freon level was low and charged. Will take the truck back in when sender is available.
Originally Posted by electod
when you changed the wheels and tires did you see any difference in mpg's please let me know i am about to do he same change to see if mpg's get better
I posted some more information about the effects of the wheel/tire swap here:
https://www.ford-trucks.com/forums/s...d.php?t=369616
061005 8,053 Miles
Service Engine Soon light turned off this morning. I'm thinking there must be a bad spot on the Fuel Sender. I'll put 5 gallons in it and see if the light comes back on.
