Header manufacturers for a 1988 e150 302? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 06-08-2005, 01:59 PM
dgeist's Avatar
dgeist
dgeist is offline
dgeist is starting off with a positive reputation.
I've been trying to find a good header set to replace the stock manifolds on my 302EFI e150 and have not found much. Ford racing makes them for 1992-newer (which probably just have extra O2 bungs and would otherwise fit fine), but are really expensive for what you get. Several other companies make shorties for the F150, but no aftermarket brands seem to make shorties that they'll admit fit into a 1988 e150 with a 302.
Does anyone here have the same or near same body/engine with an aftermarket header set that they're happy with and know doesn't hit anything under the vehicle (frame, doghouse, etc)?
Thanks.
Dan
Old 06-08-2005, 02:43 PM
pfogle's Avatar
pfogle
pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
In '92 the E150 had a complete redesign of the body, that's whay they won't work. Your best bet is going to be a build your own header kit.
Old 06-08-2005, 05:35 PM
dgeist's Avatar
dgeist
dgeist is offline
Just confirmed with FordRacingParts that theirs (M-9430-T50) is a 90-95 application and the reason it doesn't "fit" earlier models is the emissions features, not the clearance. It looks to have 2 O2 sensor bungs and a fitting for a smog pump:
http://www.fordracingparts.com/image...l/M9430T50.jpg
So, in theory, the only reason one wouldn't fit is if it's shaped differently than the ford model... (ports can always be plugged if not in use...)
Still looking for someone that HAS put headers on their e150 5.0.
Old 06-09-2005, 05:23 AM
munrow's Avatar
munrow
munrow is offline
munrow is starting off with a positive reputation.
Check out this part number @ Jeg's online, 85045, Dynomax brand, about $120, or, 89160, Hedman brand, about $165. Both are longtube headers. Give them a call to verify fit. They seem to really spend the time to explain stuff. There's probably more. I seem to recall people saying Thorley makes them, but I'm not sure.
Whichever headers you end up going with, get the coated ones if you have the option. Lots of heat issues in a van with headers.
Maybe you can go to a local shop to get a set to try for fit if you don't want to wait on shipping and such. I've got Hedmans and can't complain, but I'm carbed w/351W. Still got the heat issues.
Good luck,
Munrow
Old 06-12-2005, 12:17 PM
Mustang 5.0's Avatar
Mustang 5.0
Mustang 5.0 is offline
Mustang 5.0 is starting off with a positive reputation.
I purchased some shorties for a F150 for my E150 351. Darn things hit the inside of the doghouse. Watch out for that clearance.
They had the EGR fitting and everything too. bummer they didn't work...
Montync
04-06-2016 07:45 PM
deadboy0
Engine Swaps
04-03-2011 01:55 PM
leslane
10-04-2010 04:45 PM
Skinsfan6
17
10-30-2008 07:21 PM
HOSS270
10-11-2007 07:17 PM
Quick Reply: Header manufacturers for a 1988 e150 302?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
