Can a half-ass mechanic with no special tools rebuild a E40D
I have the ATSG rebuild manuals and they show some specialized tools to drop in a clutch pack behind the center support. It also shows several spring compressors. Do you really need these tools?
I just repaired my E4OD that I screwed up when installing a Transgo Shift Kit that required pump removal, but I chickened out at removing the center support. So the front half of the tranny is new. The back half is original.
Woh!! I also tried to rebuild my E40D and put it back into the truck. 1st and second worked great but because I did not have all the correct tools, I wound up taking it to the tranny shop anyway and cost me 350 to have them go through it. After that I figure it is worth it to let them do the rest of my trannies... also cost me less for every one I bring in. They now do most of my hard work. I still change the fluid.
Good luck in trying it yourself. Hope it turns out great.
PM the OP and find out how it all turned out. He is still on the boards.
What's with posting on two year old threads? You have to go back what, 50 pages to find these? Someone up late with nothing to do?
In response to the original question, imo, if you want half-assed results, you'll get 'em.
Jhengl
11-11-2015 09:13 PM
IowanStraight6
05-04-2011 09:58 AM
Mr.N
31
11-12-2009 06:06 PM
