Payload Capacity of 1989 E350 Question - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 06-05-2005, 12:21 AM
BonesMachine
BonesMachine is offline
BonesMachine is starting off with a positive reputation.
I am trying to find out the payload capacity of a 1989 E350 15 passenger extended cab econoline van. I have done some research and I think it's around 3500 lbs but the more I look into it the more it confuses me. I don't have access to the sticker on the door and all the seats have been taken out so I'm really just looking for a ball park figure. Can anyone help me out here that knows off hand what the payload capacity might be. Thanks...
Old 06-05-2005, 11:46 AM
packlet
packlet is offline
packlet is starting off with a positive reputation.
i believe your GVWR is probably ~9100lbs (depending on your rear axle and motor combo). Your van probably weighs in ~6100lbs (just a guess - visit you nearest CAT scales for an accurate weigh-in), leaving you about 3000lbs payload. Of course, if you've got good brakes and drive carefully, you can probably safely carry more. I know i have... :-)
Old 06-05-2005, 04:08 PM
rclarke
rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
My 89 E350 cargo van, standard body had a GVWR 9500 and weighed in at 6700lbs. I think your estimate of 3500 capacity might be a little optimistic. As packlet says above you should go weigh it to be sure.
Old 06-05-2005, 11:36 PM
Dannym
Dannym is offline
Dannym is starting off with a positive reputation.
You also want to look at the load capacity of the tires you're using.
Just how rough of a road you're taking it down makes a lot of difference too.
And of course you need to look at how high you're making the CG with the load you're adding.
Old 06-06-2005, 05:54 AM
trike1946's Avatar
trike1946
trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
My 90 is about 3000#. It would probably take more but I never tried. I decided to use a trailer instead of over loading.
Papawheelie
30
02-23-2017 05:14 AM
Alanok
1947 and Older Ford Trucks
21
06-30-2016 05:51 AM
_Rick_
Paint & Bodywork
08-31-2009 02:19 AM
jlampke
07-19-2009 12:36 AM
Fox
11-21-2007 06:38 AM
Quick Reply: Payload Capacity of 1989 E350 Question
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
