Need opinions
Need opinions
OK. Long time since I have posted here but here we go. I have always wanted to build a pull truck. I have been looking lately and can't find a cheep rolling chassis so I am considering other options. I found an 89 F250 2wd (no motor) for $500.00 (or possibly less) and the body looks to be good. I am considering this but would like your guys opinions. Any thoughts of this truck? I will need to find a cheap motor that I can build later and possibly a heavier rearend (alot of the guys use 2 ton rears). If you would like to see more specific rules CLICK HERE to see the org that I would probably pull with. It would be the 2wd Street Stock. I am not looking to have this done any time soon. Just working toward the goal. I am torn between this and just buying more toys for my diesel..... Any thoughts or ideas???
although it is fun to play around like that, it does take a bit of money and time, and never fails, something will break and cost you more money yet... as far as resale, too, forget it, you'll never recoup what you invest, the only return you can count on is the enjoyment of building it then running it... Right Rob? Occasionally there is the winnings...
Thanks guys. I have decided to hold off on the evilbay truck but I am going to pickup Kelley's 79 F250 (purchasing for the motor and tranny but if the frame or cab will work then great). Then I will try to start tearing into the motor and learning more about them. In the mean time my exhaust, gauges, and probably a chip for the smoker should be in sometime in the next couple weeks!
59flatbedford
02-14-2012 08:08 AM
Arnold Kenyon
08-15-2006 09:27 AM
lakecityg
42
03-12-2006 06:21 PM
