'55 F100 rebuild engine kit?
Ceo,
If you have the original Y-block in it, try this thread by yours truly & others:
https://www.ford-trucks.com/forums/s...d.php?t=377694
It will have some sources & options for you. As Dick mentioned, NAPA has Y-block parts as well. Summit, PAW, & Jegs can help with newer engines. If you have some specific questions, post tonight, or try the FTE Y-block forum, as there are some guys that post in there but not necessarily here. There are kits to adapt the C4, AOD, & T-5 transmissions, or you can use factory parts for the SROD or FMX with a little work.
Hope it helps, Mike
Hope it helps, Mike
There are a whole range of options depending on your budget, tools, and skills. I had my engine hot-tanked, checked for cracks (including the block, crank, and heads), and then completely remachined including decks, heads, crank journals, etc. etc. The engine shop bought all the internal parts new. The only internal parts we reused were the connecting rods, the rocker arm support posts, and a few sheet metal oil diverters in the valve train. That's the expensive option.
If you have some engine skills and want to do it yourself, have the engine hot tanked to clean it thoroughly. Then have the block, heads, and crank checked for cracks. At that point, the shop should be able to tell you if you need to rebore or hone your cylinders and/or have your crank remachined. They can also tell you what size pistons and bearings you'll need (0.010", 0.020" etc. oversize) depending on the amount of wear they find and what size they will be remachining the cylinders and bearings. You may also want hardened valve seats installed in your heads if you don't already have them. With the machining done, you can buy all the internal parts you need (valves, lifters, camshaft, etc.) from various vendors. Check out the list on Earl's World (http://www.clubfte.com/users/earl/Pa...dor_Links.html) and get some catalogs and/or look at their on-line listings. That is the least expensive way to do a complete overhaul.
There are a variety of in-between solutions depending on the condition of the block, heads, and internal components. You may want to do only the upper engine (heads, valve train, etc.). You may want to do only the lower engine (crank, bearings, pistons, etc.). Don't forget the timing chain and gears if they are worn. You may want to do some combination of both. It all depends on your budget, the condition of your engine, and what you want in the end.
