RPM's droping at idle?
Old Jun 3, 2005 | 05:10 PM
d404r7's Avatar
d404r7
I got a 1994 f-150 302, im having a problem with my rpm's at idle. The rpm's will drop and bounce around 500 when im stoped and the truck is just idleing. I had my truck checked out and they said it was the "Idle Air Control Selenoid." The truck drove fine for a couple of days, but now im back where I started. I lloked up my Hanes and it said the IAC should read between 7 to 13 ohms to work properly. My IAC is at 10.5, so i guess that its not the selenoid.
Old Jun 3, 2005 | 06:51 PM
captchas's Avatar
captchas
Guest
wecome to fte the best ford site on the web.please take some time and read the site guide lines and the read first's for the areas.
as to your truck have you tryed cleaning the tb out with carb spary? it could be cloging up.
Old Jun 4, 2005 | 11:45 AM
MustangGT221's Avatar
MustangGT221
Have you checked the computer codes yourself? Did "they" check the codes and tell you what came up?
Do a search in this forum for "computer codes" or "checking computer codes" if you need to learn how to do so.
