notice decrease in boost
Old May 30, 2005 | 05:09 PM
7.3whitemonsta's Avatar
7.3whitemonsta
i installed my predator last week and i was around 30 psi right away, the check engine light came on cause of overboost ..now it doesnt even reach 25 psi, unless i am on it for awhile... i have boost gause and trans temp didnt get pryometer yet. so i'm scared that maybe i hurt the turbo. i have stock staight pipe dumped out before the back tire.. so you think my egts got too hot and hurt the turbo??
Old May 30, 2005 | 08:13 PM
edub32's Avatar
edub32
I'd definitely get a pyrometer not only for the turbo but for the actual engine because if you have continually high egts it can cause the pistons to get soo hot to where the can expand and stick the the cylinder bores and then eventually seizing the engine..
Old May 30, 2005 | 08:15 PM
edub32's Avatar
edub32
Assuming you had the wastegate actuator mod before the predator, what was your boost without the predator..Also, how do you like your predator besides the "deboosting" that your dealing with?
Old May 30, 2005 | 11:47 PM
7.3whitemonsta
i have the wastergate unplugged as far as the predator..i love it but its my first experience with a psd so my creditability is not so great..
Old May 31, 2005 | 08:03 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Unlikely, but possible. What kind of shape is your fuel filter in?
Old Jun 1, 2005 | 12:45 AM
7.3whitemonsta
never checked it..
Old Jun 1, 2005 | 08:34 AM
mjwhip2's Avatar
mjwhip2
Also hows the air filter?
Personally I wouldn't push it very hard until you get that pyro.
Old Jun 1, 2005 | 08:18 PM
7.3whitemonsta
brand new kwik filter, so thats good i am goin to give the fuel filter a shot..
Old Jun 1, 2005 | 08:29 PM
18vtx00's Avatar
18vtx00
Smile
well i have notice something similar too, when i 1st installed my banks stinger plus i could hit 28-30 psi, but i had a bad guage to find out. so they warranteed it and i installed the new one. now she only rarely gets to 20psi. not sure if it was the guage or something else causing it. look for leaks as i did. my truck still runs hard though. i think i suprise some people daily as i pull onto the highway and pass them on the right!!! banks claims in the kit 30psi, but i have never hit it or towed much more than 3K w/ her so far either. the motr never strains so i guess i was maybe missinformed or have a slight leak some where that i have not found.
good luck., and post the fix .
