How do I tell If I have a dana 60 front end and also changing the front end hub seals
Hi there
I just am wanting to know how to tell if I have a dana 60 front end I have a 69 crew cab 4x4 and the front end is heaver than other 4x4 I've seen It has the locking hub and behind that there are 8 or so bolts just like the rear end on it I was told if was a 60 any thoughts
well another question on the same front end it has ball joint steering and the oil in the hubs leek out and the bottom of the hub when I fill oil to the plug hole dose any one have any evperiances on changing this seal?????
thanks for any help
engineguy33
thanks for any help
engineguy33
I only have 2 X 4 Ford (68) but the Rover (95) 4 X 4 has the old wiper ball style front axles. They always leaked 90 wt oil. The factory up grade has a lube called "One Shot" which is a moly base like vasoline at room temp but becomes liquid above that temp. No leaks and many owners have gone over 300K highway / off road miles no problem. I hope I helped, not confused.
.....=o&o>.....
.....=o&o>.....
Are you talking about putting oil in the closed knuckle chamber behind the tire? If so put a good all purpose grease in there. Oil is too thin and leaks out. People say use oil but many others say grease. If full it will get splattered up on the king pins. I have used oil for over a year and all the parts look like new still. Just top it up every oil change. If you aren't talking about this area then I am confused....
The axle should have a tag off of one of the diff pan bolts and if not it should also be stamped on the housing somewhere. If it is a Dana 60(which it should be) it will also be the same size as the rear. Unless you have a huge Dana 70 in the rear.
djbonsu
01-12-2021 01:59 PM
Sean Balboni
23
04-09-2013 08:02 PM
colemanw
18
12-29-2008 04:06 PM
Fordbronco69
24
09-20-2005 10:13 PM
