1978 - 1996 Big Bronco
Chirping, Squealing Sound ???
Old May 23, 2005 | 11:02 AM
cperdue3's Avatar
cperdue3
At idle, I sometimes hear a spuratic chirping noise???
Hwy driving, at a steady speed - sometimes there is a squealing noise - it goes away when I get on the gas (unlike a slipping belt)???
After reserching this site:
I thougth it might be a pulley bearing - lubed all, as well as possible
I applied belt dressing - this didn't make a difference
I also cleaned-off the belt, and tried roughing up the pully suffaces - no improvement
Could it be the fan clutch - not totally disengaging???
Old May 23, 2005 | 01:05 PM
92EBnTX's Avatar
92EBnTX
The best tool you'll have in this situation is your ears. Open the hood while the engine is running and listen. See if you can isolate a general location and go from there. There are many things that can make the sound you described: pulleys, bearings, etc. Getting a better fix on the location of the squeak will help us help you. Good luck in your search.
Old May 23, 2005 | 01:24 PM
jem270's Avatar
jem270
Actually there is an old timer’s tool called a boom stick. Cut off the broom and put one end on the part you suspect and put the other end against your ear. Try it. It really helps isolate sound problems with water pumps pulleys etc. Of course check for codes first…
Billy22
1983 - 2012 Ranger & B-Series
Jul 2, 2023 11:17 AM
fordsrawesome
May 10, 2014 09:21 PM
FoundOffRoadDominate
Jan 24, 2012 08:35 PM
erikwi
Sep 16, 2011 07:58 PM
MMARSS
2004 - 2008 F150
Jan 27, 2008 09:36 AM
