Coil spacers on top of 6" skyjackers?
Do you guys know if I can use those 2" daystars polyurethane coil spacers if I already have a 6" skyjacker lift with skyjacker coils on the front.
My concern is about the steering and front suspension... you know, will it affect my camber caster alignment? that was a big problem when I first installed my lift until I purchased a camber caster bushing corrector and new bushings for the pivot and radius arms. Plain and simple, can you use these on top of a 6" lift? (my truck is a 2WD 1988 F250)
Someone else did it under my supervising heh heh... I have pictures of the installation if you happen to need any... I purchased the new pivot and radius arm bushings from www.rockymountainsusp.com they carry daystar products and I also purchased the skyjacker lift from them. They'll match any price you come up with. I haven't checked if they carry what I'm looking for at this moment
shuttlevalve
08-18-2008 10:55 AM
