Well I talked to my Head Porter today!!
Old 05-18-2005, 09:36 AM
RapidRuss's Avatar
RapidRuss
RapidRuss is offline
FE "Freakin Expensive"
Originally Posted by Freightrain
With the ol Moroso "speed" calculator it put me at 550~ hp. I don't think it's too far out of line. Course what good is "big" hp numbers if a car runs 13's.....LOL!!!!
The strange part is I took about .02 off the heads this winter and the car picked up .15 and 4 mph right off the bat!!! Hmmmmm? It went 11.58 @ 115 last year, 11.43 @ 119 first week out. It has not run those kind of numbers since the old motor.
BTW....BUDGET and FE...........DON'T fit in the same sentence.....
Larry..I think you should stop using the Moroso Calculator!! LOL..
On my EA3 Sim... I get 11.31 et. @ 119mph 650HP Pushing 4100lbs...
Russ
Old 05-18-2005, 09:37 AM
Six Niner's Avatar
Six Niner
Six Niner is offline
thanks for the reply russ. ive been thinking about getting another set (i.e. better) to start on and replace the c6's when done. hopefully a full port job and cj valves. anyway its always something...lol.
Old 05-18-2005, 09:48 AM
RapidRuss's Avatar
RapidRuss
Well Larry, I think you need to quit using the Moroso Calculator?? LOL
I ran it thru the EA3..and came up with...
ET,,11.31 @ 119mph and 650hp pushing 4100lbs?? OOPS!! Sorry for the Double post...It didnt look like the first one went thru?? lol..
Russ
Old 05-18-2005, 10:08 AM
Mike G's Avatar
Mike G
Mike G is offline
Larry / Russ:
If you don't mind here, can I ask if you two have compared $$ to spend/spent to get the numbers you are both looking at. I guess I'm asking the age old cost/benefit question, how much to get the iron's running like the Ebrocks...
--Mike
Old 05-18-2005, 10:16 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
I bought bare Eboks, put everything in them, the "port" work put me back $600. I'd have to really research the overall total cost in heads. I don't think I really want to know...LOL!!! I"m thinkin in the near $2k range for heads alone, complete. I guess if you start with iron the same way, it might be cheaper for the castings, but you save 42 lbs by using the Eboks! The only difference is the old castings will need guides/seats........so it might wash in the end? So the only advantage is WEIGHT?
As for HP, Russ. Your newer programs might be a bit more scientific then the old slide rule Moroso calculator?? LOL!! Does that SIM take into consideration slippage anywhere?? Does it conpensate for stick or automatic?
I know I will never get the ET that the MPH comes to. I don't have the tire/traction issue settled enough to get the ET. Too much slip/slidin' goin' on
Old 05-18-2005, 11:35 AM
RapidRuss's Avatar
RapidRuss
Oh Yeah Larry, it Take's into account everything..... Right down to What tires you use and the track condition, Air temp,Borometer, Tire width, Height, Rollout,Stall for auto,ETC...
And Mike G.... My Stock C2SE-A's were free..but all stock...So to My porter is going to Do all the Machining and Poert work, and supply all the Manley Valve's,hardened seat, Isky springs to match the CompCam, Titon seals, New Valve Guide's, Retainer's and 10* keeper's, and Competition Valve job for $680 to my door!!
Hope this Helps!!
Russ
Old 05-18-2005, 12:21 PM
Freightrain
Originally Posted by RapidRuss
$680 to my door!!
Russ
I was ROBBED!!!!!!!
Old 05-18-2005, 12:46 PM
RapidRuss's Avatar
RapidRuss
LOL..Not really Larry...you can tell everyone you have Aluminum heads...and I cant...
Plus I do believe the Ed rpm heads fully ported will smoke the Stock ported one's...
But if I'am just looking at 500hp..Something just to have fun with street/strip...
I couldnt justify spendeng $1000 on bare heads and another $800 to a $1000 for the parts and the port work... 60 or so pounds more than your FE...Maybe more??
Russ
Old 05-18-2005, 12:47 PM
RapidRuss's Avatar
RapidRuss
Edit
RapidRuss390
Old 05-18-2005, 02:28 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
You know, I have a set of flow data for ported C4AE's, and a set of flow data for Keith Craft Stage 2 Edelbrock heads. The ported C4's flow slightly better than the stage 2 edelbrocks.
Russ, I think you'll be really happy with those heads.
Old 05-18-2005, 02:40 PM
RapidRuss's Avatar
RapidRuss
Yeah Kurt , I think for what its all going to cost...... I'll be pretty happy all in all... It wont be a very high tech motor...But it seems to have good low end TQ and Plenty of HP... For what all it is?? Or isnt?? lol..
I have to check up on My DD2 Sim..I seem to be getting a conflick of alot more hp out of the EA3.2......and there usually within about 6 to 8 HP from one another?
With 2.090" I and 1.730'E Fully ported and a Holley 870cfm, I'am getting 504hp at 6000rpm and 480lbs of TQ at 4500 to 5000rpm... with the Cam straight up??
And alot more on the EA3....Something is strange??
Russ
Old 05-18-2005, 03:14 PM
Freightrain
If you can get that kind of numbers from a stock head...that ain't bad..especially at THAT price!! I need to look, I think I might have a set of C4's at home. They might just make a nice set of street heads.
Got a whole 390 sitting on a stand. Could be a hot rod motor for the '67 F100
  #28
Old 05-18-2005, 03:19 PM
Putt's Avatar
Putt
Putt is offline
Hey Russ, I went to the Stan Weiss site...how do you get to the head flow data??
I'm sure it is simple, but I must be simpler!!!
  #29
Old 05-18-2005, 03:40 PM
RapidRuss's Avatar
RapidRuss
Putt on the Left of the site as I recall it said something about heads and head flow..I clicked on that and then clicked on ford...then ran down the list til I found FE heads..
I think?? lol.. I'll have to go check to be sure how I did it?? lol..
Russ
  #30
Old 05-18-2005, 03:43 PM
rusty70f100
Well I'm going to run some numbers through my DD2k, when I get some time. Cleaning out the attic now... ugh. Electrician coming tomorrow, getting kitchen redone. It's a mess around here.
But yeah, when I get some time, I'll run it.
You know Russ, a roller cam might be the way to go with that motor!
Quick Reply: Well I talked to my Head Porter today!!
