Sponsored by: Real Truck
Starting troubles still.
Old May 15, 2005 | 10:34 AM
Frisco the Dog's Avatar
Frisco the Dog
Hello, I posted this yesterday in the 6.0 forum with no response;
I am currently having starting troubles with my 6.0. When using my command start (python881xp) it is not firing up the first time.It does do a 20 second delay for the glow plugs. All but once it started on the second attempt. It had done this to me the odd time even before I had the remote start installed,(feb) where the first attempt failed and then after re doing the glow plug procedure fires up immediatly, with a lot of smoke and smell. Currently it is happening on every (remote) start attempt. My code reader shows water in the fuel, but nothing to do with glow plugs. Any ideas?
The remote start and hand start worked perfectly fine in minus 30 c to minus 5 c, but the problem mainly happens at around freezing. minus 5 c to +5(about 32 f)
Old May 19, 2005 | 06:59 PM
n578md's Avatar
n578md
Here a small TSB on that subject:
Intermittent Unsuccessful Remote Start and/or Stall After Remote Start:
Some trucks may exhibit a no start condition when using a remote start system. Or, the the engine may start and run for up to five seconds then stall. The start/stall condition may repeat itself up to four times without operator input. The technician should contact the Ford Remote Start Technical Hotline for diagnostic assistance. A tach signal booster, P/N 102818-2, may be needed. Broadcast Message 1722.
Old May 20, 2005 | 06:03 AM
glafond's Avatar
glafond
I don't know what year your truck is, but, the '05 6.0 does not need the tach
input for a remote start. the PCM will disengage the starter when the engine runs.
i'm not sure what year they started this feature.
you can tell when you start it by hand, just hold the key in the start position, it will not grind the starter.
Old May 20, 2005 | 06:08 AM
glafond's Avatar
glafond
One other thing. I discovered that the supply wires for the glow plug module are not wired directly to the battery. They are spliced into the alternator output cable inside the wiring harness, and then connected to the battery.
Check the passenger side battery Aux. connections
tap1946
Jan 17, 2012 07:33 PM
patshea814
Dec 8, 2010 05:24 PM
HKusp
75
Jan 8, 2010 11:36 AM
deckguy
Nov 20, 2005 01:55 PM
Twin Tritons
Feb 8, 2005 10:17 PM
