1985 F150 Truck bed
Old 12-31-1969, 06:00 PM
Guest
Guest
Posts: n/a
1985 F150 Truck bed
Old 08-23-2000, 01:50 AM
darougeman's Avatar
darougeman
darougeman is offline
1985 F150 Truck bed
Looking for bed in very good shape. Single or dual tank. What years are interchangable? I'm located in Florida, Orlando area.
Thanx
Old 08-23-2000, 11:20 AM
fiddy's Avatar
fiddy
fiddy is offline
1985 F150 Truck bed
my dad has an 84 f-250 that has a 93 box on it. there might be slight cosmetic differences around the wheel well, but any box 80-96 (97 superduty) will bolt right on. hope that helps!
doug
Old 08-23-2000, 03:29 PM
maveric's Avatar
maveric
maveric is offline
1985 F150 Truck bed
Unless you are going to put BIG fender flares on the front and rear of the truck, STAY AWAY from anything newer that 86. The beds are the same from 80-86 for the body style that you have. If you look at the fender wells on your truck, you will see how it has a distinct body line around the opening. On the 87 and newer beds, the lip sticks out instead of in. Compare the two, and you'll the difference. THe newer beds will fit the older trucks (I've even seen the 96 beds on a 72 truck, looks goofy, but I guess it's better than nothing). It's a matter of opinion on what you want to do. I had the option of using a newer bed, but figured it was worth the extra time required to find a good bed from an 80-86 and keep the same lines. Looks better in my opinion.
Chris
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
08-22-2012 11:39 PM
Quick Reply: 1985 F150 Truck bed
