tranny problems
Old Apr 25, 2005 | 09:27 AM
4.9LFord's Avatar
4.9LFord
tranny problems
my '95 F-150 has a 4.9L engine, and the mazda 5speed tranny and second gear is really tough to put it into and it makes a clicking sound also, whats wrong here?
Old Apr 25, 2005 | 09:50 AM
javi2001's Avatar
javi2001
It sound like a lot of wear on your tranny, there is a small pinion designed to sinchronize gears, if it has wear, shift is geting harder.
Any way you'll need removed the tranny and have checked...
Old Apr 25, 2005 | 03:41 PM
4.9LFord's Avatar
4.9LFord
i would really like to swap in an automatic tranny in place of my 5speed. has anyone had this done? if so besides the tranny, what other parts are needed?
Old Apr 25, 2005 | 03:42 PM
4.9LFord's Avatar
4.9LFord
oh and in reference to the noise from my 5speed, it only occurs when i'm coasting and have the clutch engaged and am trying to put it in second, and when it is just idleing without the clutch engaged.
Old Apr 26, 2005 | 07:46 PM
javi2001's Avatar
javi2001
Stering colum shifter, drive shaft modification (Shorter or longer one), slip yoke, some vacum lines and/or wiring modifications also.
I recomend use AOD, AOD-E, E4OD or C6 + some aftermarket overdrive
Old Apr 26, 2005 | 07:54 PM
javi2001's Avatar
javi2001
I don't have a lot of experience on manual trannys, but it seems to me you will need remove the tranny to be fixed beffore damage gets worse...
Old Apr 27, 2005 | 06:03 PM
4.9LFord's Avatar
4.9LFord
i wish i could pull the tranny right now, but this is my daily driver. The tranny still shifts pretty good, and doesnt pop outta gear or nothin, so i'm gonna have to wait till i have some down time to pull it and take it to the shop, which really sucks
