Gearing Change
Old Apr 24, 2005 | 11:09 PM
94fordlover's Avatar
94fordlover
Gearing Change
I have a 94 f-150 with inline 6. I have 31bfg all terrains on them. Ive been reading about gear changes in the dif. Should I change my gear ratio, and will it help me out at all?? I want more accelaration off the line and be able to spin the tires. I have already put an exhaust and k&n on. I will be putting a tb spacer on too. Thanks
Old Apr 24, 2005 | 11:31 PM
85e150's Avatar
85e150
What trans and diff gear do you have now? You can put 4.56's in and spin away and have a 55 MPH top end if you'd like. You don't really have a wheel spin and acceleration unit there with a 300 six.....
Old Apr 25, 2005 | 08:22 AM
94fordlover
I got an E40d. Not sure on the gearing.
Old Apr 25, 2005 | 09:22 AM
oldhalftons's Avatar
oldhalftons
what gears are in it now?
If it has 2.75-3.08s get rid of them. You should be able to 31" tires EASILY with 3.50s/3.55s
Old Apr 25, 2005 | 09:36 AM
94fordlover
So how do i found out what gears do i have?
Old Apr 25, 2005 | 09:49 AM
Gerry Lutz Jr.'s Avatar
Gerry Lutz Jr.
well look at your door driver side and give the guys the numbers they should be able to tell you what it is. As for spinning you should be able to easily. Btw don't buy a throttle body spacer they do absolutely natta except take up space for efi's.
BRay09
Dec 30, 2015 06:11 AM
94f150la
Mar 11, 2015 12:04 PM
Boss300
Sep 5, 2010 09:17 PM
stu37d
1983 - 2012 Ranger & B-Series
Apr 18, 2009 03:29 PM
dsthubbins
23
May 17, 2007 01:06 PM
