Sputtering 6 Banger
Old Apr 23, 2005 | 10:27 AM
jenral's Avatar
jenral
Sputtering 6 Banger
Ok lets try this again. I hope this is an easy fix but ........here we go. My 84 300 cid I noticed over the last few days sputters and all but dies when I go up a hill on the highway. It starts fine, drives fine and when I hit the gas she accelerats fine. Till I get to a hill at highway speeds. It's timed right, at least at idle, and the fuel filter is less than a year old ( I'm gonna replace it any way ). It does'nt matter if I'm on the front or rear tank either. Once I hit the top of the hill and back on level road, after driving a kilometer or 2 everything is back to normal. Any help would be greatly appreciated...thanks
Old Apr 23, 2005 | 06:03 PM
Franklin2's Avatar
Franklin2
You are on the right track. It does sound like a fuel starvation problem. When you quickly accelerate, you are using fuel stored in the carb. But when you pull a long hill, the reserve in the carb is used up and is not being replaced quickly enough. Check:
Fuel filter
Fuel pump
sock on the pickup in the gas tank.
Old Apr 23, 2005 | 08:10 PM
jenral's Avatar
jenral
Darn it... I forgot all about the sock...thanks for the reminder.
Old Apr 23, 2005 | 11:38 PM
Chiefrider007's Avatar
Chiefrider007
Sock would probably show up when you run under a low fuel condition, gas sloshes and picks up junk etc. Fist thing is how old are the plugs, wires, cap and rotor? Then how old is the Control Module? My guess is that your ignition system is at the beginning stage of a malfunction and any one of the before mentioned items can cause the same problems.
Good Luck....
Old Apr 24, 2005 | 09:19 PM
jenral's Avatar
jenral
Turns out the fuel filter was so plugged I could not even blow thru it. I gues I should have mentioned that I had givin the truck a complete tune up 3 weeks ago. New plugs, wires, rotor, and cap. The coil is less than a year old and the Distributor advance is also only about 8 months old plus she was timed reasonably close. But it's all better now with that 3 dollar filter. As far as the module goes, I have no idea how old it is, since I've only had the truck under a year. Thanks for all the help guys.
Old Apr 25, 2005 | 08:34 AM
ronclark's Avatar
ronclark
If you had a stopped up fuel filter in less than a year, Then I would be concerned about trash (possibly rust) in the tanks causing the fuel filter to stop up. You might want to pull the tanks sometime when you have time and clean out before the problem shows up again.
Old Apr 25, 2005 | 06:18 PM
f'n250's Avatar
f'n250
carry a spare fuel filter so you can change it wherever you are. sound like your tanks are full of crap as mentioned. you've had it less than a year, did it sit unused before you drove it? If yes it may clear itself after a filter or two.
Old Apr 29, 2005 | 06:13 PM
jenral's Avatar
jenral
I bought it off an older gentleman who isn't allowed to drive any more. The truck did sit for long periods of time in his garage. The rear tank he says is less than 3 years old, the front is original. I will take your guys advice tho and find time in the summer to pull the tanks and check em out. As far as the extra filter goes have wrenches and a new filter in the glovebox. Thanks for all your help guys
fluidp
Apr 16, 2014 08:35 PM
ford7379trucks
Oct 21, 2010 10:09 PM
sonsila
Feb 21, 2010 05:20 PM
Ford4x4-JD70AB
Mar 9, 2008 10:42 AM
dkizerian
May 8, 2003 01:33 PM
