Which rear gearing is best?
on
Originally Posted by Sixoh
Imlowr2 mentioned "adjusting" the speedo for different gear ratios. How is that done? My speedo runs at about 5-7mph faster than I'm really going with my current 351M/Cruise-o-matic /2.75 rear end w/215/75R14s.:
Vern
To change the speedometer you will have to change the gear on the end of the speedo cable on the end that goes into the transmission. It is easy to do and involves just pulling the cable from the tranny. Your Ford dealer and maybe some parts stores should have a different count gear to attach to the cable. Use GreatNorthWoods suggestion for the gear count to get one that will be correct.
on
06
7.00x15 Light Truck Tires.
No, you are only Partially correct.
That is the Size that IS listed In Relief as Cast On the Sidewall of the Tire.
And that IS also One of the Tire Sizes Listed in my Original Owners Manual.
I Do Not use the New Style of Bleedin' Rediculous tires on my '58 M-100 fore my Original Rims were Not designed to Use these Short Wide Excuse for Tires they sell these days, Plus I Just Do Not Like them.
Originally Posted by sparky30_06
Col Flashman This does not help me fore I run 7.00x15s & that Calc is not set up for my type of tire measurement.
what size tire are you running??? that is a rim size you posted
on
Here's a Formula for figuring out the correct gear.
(T*G*20.2)/D = Gear needed
T = Gear on tranny tailshaft normally 8 or 7 tooth
G = Gear Ratio
D = Tire diameter
(7*3*20.2)/26.7 = 15.89
So you need a 16 tooth gear for 3.00:1
(7*3.25*20.2)/26.7 = 17.21
So you need a 17 tooth gear for 3.25:1
G = Gear Ratio
D = Tire diameter
Originally Posted by GreatNorthWoods
Its depends on what your daily drive is. Mine is 38 miles each way of open road both interstate and back woods. I had a 302 with a C4 and 2.73s in the back. Highway speed 70, back woods speed 60, average mpg 17.3. Plenty of zip for me, but I am easy to impress I have never had much power.
Truck was reworked for the last 9 months and we brought the 302 up to 315hp and added an AOD plus kept the 2:73. The goal was for highway speed (70) and mpg of 20. Test flight begin in May.
Jet Jock
"I drive a 'girly' 302 because, when I want to go fast, I go to work"
Jet Jock
Originally Posted by 51ford fan
What trans, and tire size are you running with the 3.25s
wadar1969
11-04-2011 01:20 AM
Mr Mayo
22
08-22-2008 10:30 PM
Cowboy34
17
05-17-2006 01:46 PM
