Alaska Chapter Join Chapter, Leader:
missing in overdrive
Old 11-14-2006, 03:21 PM
murray44's Avatar
murray44
murray44 is offline
Cool missing in overdrive
I have a 4.6 now that it's cold The truck starts missing in overdrive on up hill at 60 to 65.The hills from valley to anc .Turn off od runs fine ,Whatsss up
Old 11-15-2006, 12:40 AM
mlb4966's Avatar
mlb4966
mlb4966 is offline
Hi Murray. Is the 4.6 in the F150?? If you do not get any answers you might want to ask this same question in that section.
Old 11-15-2006, 11:52 AM
murray44's Avatar
murray44
murray44 is offline
No it is in a F250 4x4 with 48,000 on it
Old 11-15-2006, 11:55 AM
murray44's Avatar
murray44
murray44 is offline
Sorry it is a 1999
Old 11-19-2006, 01:26 PM
mlb4966's Avatar
mlb4966
mlb4966 is offline
Ok I would suggest posting this in the Super Duty section. Someone there might had a suggestion
Old 11-19-2006, 09:09 PM
arcticoffroadingfish's Avatar
arcticoffroadingfish is offline
the 4.6 is not a superduty engine it would be the light duty
Old 11-19-2006, 09:11 PM
what are your rpms while you are in overdrive? and are there any other symtpoms that its has?
also are you in 4hi or 2hi
Old 11-20-2006, 12:53 PM
murray44's Avatar
murray44
murray44 is offline
Rpms ? No rpm guage running in 2hi .Just start missing on a incline
Old 11-21-2006, 04:11 PM
what is your gear ratio in the rear axle you just may be at too low RPM, its possible anyway or you may just be hitting ice and then pavement on the incline. does this happen on any incline or just this one? if its just that one try another incline and see what happens.
Old 11-22-2006, 02:31 PM
murray44's Avatar
murray44
murray44 is offline
on any incline, no ice on the road, If I keep my speed up Like 70 run fine I like going the speed limit,gear ratio? It is a stock truck from ford I think they would put the right rear end in but never know .
Old 11-30-2006, 10:21 PM
do you have any check engine light? it is possible that you have a bad coil pack and it is arcing to the side or a air leak around the intake or a hose...
Old 12-06-2006, 02:35 PM
murray44's Avatar
murray44
murray44 is offline
Had snap on code reader on it ,it shows on missing ,must be trani will take it there and see what they say
Rob4674
1999 to 2016 Super Duty
05-29-2016 07:23 AM
riverratba
18
12-22-2013 12:03 AM
dagofast2112
12-15-2010 03:06 PM
Garff
1997-2006 Expedition & Navigator
11-20-2010 05:36 PM
Copperhead22
07-23-2007 08:17 AM
Quick Reply: missing in overdrive
