anyone done this to a bronco?
i'm finally deciding to get rid of this worthless car and drive my bronco full-time, hell yes! i'm going to put all of my system in it too and i was curious as to what subs sound like in the back of a bronco..... like i said, i'm use to just hearing them out of a trunk. so i want to know what subs are like in the back of a bronc. thanks guys
I've moved my box all around in my little bronco (BII) and I've found the best way is facing the back. I've done a little research on this because usually speakers sound better when they're facing you, but in the case of subwoofers, it's opposite. There's several studies to show that both the dB level is higher and the SQ is better.
Originally Posted by wyziwig6
you can't just say they WILL sound better. every vehicle is different, and not everyone likes the same sound.
Try both ways..and see which direction YOU like the best.
Originally Posted by RomerB2
There have been several studies in all sorts of vehicle types ranging from Mini Coopers to Sedans (with the subs in the trunk) to full size trucks and SUV's and all showed that the dB level was higher in the front seat and the sound quality was better.
it varies for every vehicle...there is no "solution" as to which way sounds better or is louder (btw, sound quality is subjective)
Every car has a different transient response...you CAN NOT say one thing applies to all vehicles.
I would love to see the results of those so called "tests"...
Yea about the subs facing the rear.. sorry bout the confusion.
Some individuals tested their cars and their friends cars with frequency analysers on microphone and dB meters and all sorts of crap. I'll look for the stuff later and post it. Personally I don't care, it's just I was saying some guys did this and in their cases they found that subs facing the rear of the vehicle sounded better in every application.
