My drivers side door will not shut tight. Is there a simple way to adjust the doors? It is a '92 F150,4.9L, M5OD. I did a search on this topic but did not have much luck. Any help will be much appreciated.
CMOOR99 ...
I had the same problem with both doors on my '91 ... The plastic sleeves on the door latch pins were worn off ... I got new sleeves at Auto Zone, unscrewed the latch pins, put on the sleeves, screwed the pins back into their origional position ... Vola! ... Like new! ... Since this fix is so simple ... You probably won't get that lucky ...
Regards, DR
