locking axel or not???
Old Apr 17, 2005 | 09:49 PM
pantherscat's Avatar
pantherscat
Smile locking axel or not???
Hi all, just a quick question. I have a 79 f250 with a 300 6 cyl in it. It s a custom. I was stuck the other day and I thought I noticed both tires spinning . I have no Idea, but is it possible this truck has both tires as drive tires? Not to familiar with the old fords. thanks
Old Apr 17, 2005 | 09:58 PM
LxMan1's Avatar
LxMan1
You can post the axle code off of the data sticker in the doorjam, or look at the tag on the rearend and post the numbers here. We can decode it for ya.
Old Apr 17, 2005 | 10:22 PM
Mil1ion's Avatar
Mil1ion
If the axle code on the rating plate on the door that has an H in it.
ie : H2 or H4
Yes that is called Limited Slip or Traction Loc
Old Apr 18, 2005 | 08:06 AM
Dustin_86's Avatar
Dustin_86
Mine has H6
Old Apr 18, 2005 | 02:04 PM
6Fastback7's Avatar
6Fastback7
Axle Codes
Where can I get a list of all these codes, for the axles? For all the 79 back ford trucks.
Richard
Old Apr 18, 2005 | 04:50 PM
Mil1ion's Avatar
Mil1ion
H2,H4 were just examples,thus the ie:
Just click my user name then click my Homepage Link.
You shouuld be able to find it from there.
Old Apr 19, 2005 | 08:14 AM
6Fastback7's Avatar
6Fastback7
Thanks for the info.
Later
Old Apr 19, 2005 | 10:28 PM
tractor_man83's Avatar
tractor_man83
easiest way to tell if the axle is limited slip or locking is to jack both rear wheels off the ground with the trans in park or in gear if man and the engine off try to turn one of the wheels by hand if on turns foward and one turns backword its an open dif if they wont turn try it in nuetral. an open dif will spin both wheels alot of the time if in lose dirt or low traction situations
Old Apr 20, 2005 | 09:01 PM
LxMan1's Avatar
LxMan1
It may not react that way if the clutches are shot. I have seen them turn opposite directions when the clutches are slipping badly.
