Ground-wire fried out?
Old Apr 15, 2005 | 01:50 PM
GeneStoner's Avatar
GeneStoner
Why would just the ground wire on an alarm LED burn up?
All of the other wires are perfectly operational and in-tact on the unit.
Old Apr 15, 2005 | 05:43 PM
Franklin2's Avatar
Franklin2
The most common reason for a ground wire to burn up, is it's usually asked to carry too much load because the main ground wire is not connected or has failed for some other reason.
Old Apr 16, 2005 | 04:48 PM
GeneStoner's Avatar
GeneStoner
Hmmm. On this particular item, there is only one ground...
Old Apr 19, 2005 | 04:33 PM
GeneStoner's Avatar
GeneStoner
Should I increase the gauge of wire for the negative wire to pre-empt another burnout?
Old Apr 19, 2005 | 07:47 PM
Franklin2's Avatar
Franklin2
I don't know exactly what you are working on, so I can't really say. The first statement I made was a general one for lots of cases. What brand is ths car alarm, and what exactly is it's function(blow the horn)? Do they have a website with some info and diagrams? Did you take the unit apart to find the LED problem?
Old Apr 20, 2005 | 04:39 PM
GeneStoner's Avatar
GeneStoner
Actually, I let the smoke out of the LED (emanated from behind the dash) and upon inspection, just the neg. wire TO the LED itself (has it's own ground) had burned up. Everything else is in tact and operational...
Old Apr 20, 2005 | 06:58 PM
Franklin2's Avatar
Franklin2
Do you think you accidentally bumped it against something and made it burn out? It may be ok if you put a new wire on it.
Myfreeford
13
Jan 2, 2024 06:33 PM
cgi2099
Oct 5, 2011 07:12 PM
rmalottwtes30
13
Apr 8, 2008 05:34 PM
dieselbogging
Nov 22, 2006 09:54 PM
kcw12
May 15, 2003 07:29 AM
