proportioning valve and bleeding brakes
OK i had the same problem and it was a real headache! It's 1 of 2 things.(hopefully for you the 1st)If the pin is in all the way you must pull it out to bleed the rear (it'll stay out and move w/the brakes when there's some rear line presure built up) the second and what was wrong w/mine can accure on neglected systems where the fluid is very dirty. The P valve must be removed and completly taken apart to clean out the valves and seals of whatever junk is blocking it. To check which passages are blocked I used comp. air and a rag.
Good luck, I tryed and gave up about 3xs before i finally got it.
dthut
04-10-2017 07:49 AM
s.squared-39
12-05-2016 04:46 PM
hurst1979olds
04-20-2016 11:11 AM
raven3
11-01-2015 11:10 AM
HardFordCore
02-21-2006 11:25 PM
