coke spilled on my carpet
I had a coke that "mysteriously go a hole and leaked bad all over the pass side carpet and mat I go as much up as I could. But I'm affraid the stain is still there. Will the muli-purpose Armerall cleaner get the stain out I recently cleaned the carpet with a house hold steam vac with a stain gaurd cleaner if that helps. What is the best cleaner.
Dustin
Dustin
For coke; the best cleaner would be hot water. and per gallon of hot water, the anount of dry laundry powder that you can fit on your pinky nail. Rinse with 1/2 cup/gallon vinegar/water. No liquid laundry soap or dish soap. Use a spray bottle and the nozzle of a wet/dry shop vac. In my experience as a carpet cleaner, the best way to get out spills was by flooding the area with hot cleaning solution and sucking out the water with the concentrated vacuum at the 1.5" hose end instead of the wand and repeating until the stain was dissolved and sucked out - usually two or three times. Mind you, this was a PTO truck mounted unit that could do a decent job with 400' of hose attached; in other words, it really sucked.
Best/simplest way ive used so far (my father and i use it A LOT) wesleys bleech white tire cleaner + hot bucket of water. Spray the cleaner, grab a brush, dump it in the hot water, scrub, dry with towel. Always worked for me and if you do whole vehicle floor and seats itll make it smell good lol. No it doesnt hurt anything.
bucswin
Appearance & Dress-Up
08-30-2012 02:19 AM
