Removing those sunvisor stickers
on
I don't know that I would use Goof Off on sunvisor material...If I really felt that I had to get the sunvisor stickers off I would first try to heat it up with a hair dryer. See what happens.
Haven't gone out to look at mine but it seems that I remember that some of these stickers are impregnated into the material...if so would be hard to remove.
The other thing is...what if you only can get part of it off. Yuck...that would look pretty bad IMO.
I tried Goof off on the truck I turned back into Ford....it worked, VERY scary...I was worried I would melt the visor....I am NOT suggesting to use the stuff...I would HATE to suggest something that could ruin you visors SO USE AT YOUR OWN RISK....I do know the quicker you get the sticker off...i.e. when the truck is new you are better off....TAKE THE VISORS OFF THE TRUCK...do it in the house where they will lay flat ...
I got mine off... boy was that a hassle. My visors are the soft cloth type. First off please note that my visors are black and I can not gaurantee you'll have the same visual results that I did. ....
Test the cleaning process first in an area to see if the cleaner (GoofOff) does not leave any evidence!
Here what I found works and doesn't work. Remember that you'll need lots of time (I think it took me 2+ hours to try all my methods and types of glue removers). Make sure you don't poke or cut a hole in the fabric!
Here is what I found to work. I tried heating them up... didn't seem to help. I eventually ended up crossing my fingers and going for it. The best tool was a good pair of flat tipped tweezers. I found the corner (check all four) that was the least secure (these things are a cloth iron on and bonded real well). I started by lifting the loosest corner and slowly pulling (which tears the stickers) from left to right or vice versa... this is the sticker grain direction. You'll only get about an 1/8-1/4" up at a time. Tear it back a 1/2" or so and then lift the next bit of the sticker and pull it back the 1/2". Continue until you've got it about 3/4" wide. Then firmly press against the fabric with one hand (help against streching it badly) and with the other hand grab the loose area and tear that entire section off. This will leave the dried on glue and since I have a Harley the visors are black and the glue looked real bad. Continue this same approach with picking up the next area (corner you started from) and tearing off each section lengthwise.
Once they are off... I removed the glue with a clean, soft, no color cloth to prevent bleeding (I used paper towels but they did leave lots of fiber) Put GoofOff on (GooGone does not work) and dab and rub the area. Keep rotating the cloth to a clean area so the glue stays on the cloth and doesn't soak back into your visor. You won't get it all off the first try. Wait a couple hours to completely dry and vacuum the loose flakes and fibers off. Then start the cleaning of the area again with a clean cloth. After a few time (3 for me and acouple days) you'll have sticker & glue free visors.
TAKE YOUR TIME and you'll be happy you did !!!!!!!!!!!!!
Mattress tags?????
Tim,
When your doorbell rings answer it! It will be the mattress tag police there to arrest you for illeagal tampering with a warning device. You had better check your pillows as well to be sure they comply before the tag police get there.......
Wish I had this forum when I attempted to remove my visor stickers while waiting for my other half to come out from some store... It was not pretty to say the least
